Results 1 to 15 of 22
Thread: Just picked up a 1985 TECATE! tell me what you think
    Mar 2007
    lakeville ma
    605
    just picked her up runs good for 2 mins then stalls like has no gas,but i got her home, hurt my foot bad 20 mins ago kicking it over,have to wait till tommorow to get her going,also what are the symtom's of bad reeds?
    ricky stator??? the guy said he put 1 in then he handed me this one and said this was the ricky?
    NO 3 WHEELERS CURRENTLY SOLD THEM ALL
    02 GSXR 240 kit STRECHED
    03 BANSHEE 421 CUB
    07 LTR 450
    08 RZR
    05 f7
    07 KLX 110
    670 ho skidoo powered banshee
    1985 nacs kx 80 race quad
    Mar 2007
    lakeville ma
    605
    03 BANSHEE 421 CUB
    07 LTR 450
    08 RZR
    05 f7
    07 KLX 110
    Mar 2007
    lakeville ma
    605
    ive pulled the carb off 5 times today,it will now only run off the carb cleaner, every thing is super clean even ajusted float's up and down, no clue what to do bike has awsome compression(ask my ankle) evan pulled the reeds out and checked them out, think there boyense and looked at the piston it looks new. will my 250 r carb fit? what am i doing wrong,there's a vacumm port on the side ofthe carb is it just a drain? what should i do? i can't walk any more my foot's messed up bad!!!lol
    03 BANSHEE 421 CUB
    07 LTR 450
    08 RZR
    05 f7
    07 KLX 110
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Looks really clean man, good deal. Did you pull the plug see how it looked? Mabey your flooding it out? Or the plug is bad?
    TF 07,08,09,10,11,12,13,14!
    Mar 2007
    lakeville ma
    605
    changed plug ,plug is dry
    03 BANSHEE 421 CUB
    07 LTR 450
    08 RZR
    05 f7
    07 KLX 110
    Apr 2006
    PA
    1,464
    Get a new plug. The day I got my 200x the same thing was happening and I checked over everything multiple times and found nothing. Then I replaced the plug and it ran awesome.
    Jul 2006
    Are you sure it has spark . Mabe the stator is bad . sometimes it has spark and it will start and run for a min and then it will die and wont fire back up . Thats when you want to make sure it still has spark. It could be the timing mark is off or the pick up on the fly wheel dosent match the stator . It will run but kick back like a mfer and run like crap. I had all of these issues.
    Mar 2007
    lakeville ma
    605
    it kicks back like a mo fo so change the stator with the 1 in the pick?
    03 BANSHEE 421 CUB
    07 LTR 450
    08 RZR
    05 f7
    07 KLX 110
    Jul 2006
    You could but you need to know what flywheel your useing. If its a ricky with a ricky stator you should be good there. If not , say u have a ricky stator and a oem flywheel it may not work. I had 2 tecates and took out the flywheel and stators .they were different flywheels and I got the stators mixed up and it was doing something like what your saying . the pick up was off . Once I figured that out I was a ok.
    Sep 2006
    Shreveport, Louisiana
    888
    Maybe the exhaust is plugged-up. Dirt dobbers or mice coulda built something in the pipe. Did you look at the pipe? Take the headpipe and silencer off, seperate them and run water through the headpipe. Look inside the silencer, should be straight through, easy to see through.
    Just a thought. Chris
    >>>>>>>>>>>>>>>2007 Yamaha Raptor 700R>>>Cross Country Racer<<<<<<<<<<<<<<
    www.myspace.com/bluelionracing
    Support my 2009 sponsor:
    For all your ATV suspension needs.
    Mar 2007
    lakeville ma
    605
    will try 250 r carb first then swap saitor ,ill let you guys know how i make out
    03 BANSHEE 421 CUB
    07 LTR 450
    08 RZR
    05 f7
    07 KLX 110
    Oct 2005
    saratoga, ny
    2,819
    nice looking t3 you grabbed up there black86tri-z. that tank looks beautiful....
    Mar 2007
    lakeville ma
    605
    do you need a puller to pull the flywheel off on this thing? i think the timing's messed up because i just wentand started my 350x and it was way easyer to kick over than this and it just dont feel right
    03 BANSHEE 421 CUB
    07 LTR 450
    08 RZR
    05 f7
    07 KLX 110
    Could be timing or the stator - Tecates stators seem to be a part that fails. Just an Ohmm meter can test that. I wouldn't be so dead set on changing the carb, did you remove every jet? Are you certain there is no intake leak where it bolts to the carb or where the carb bolts on??
    Yep, you need a puller....
    Oct 2005
    saratoga, ny
    2,819
    yeah check the boot, is it dry rotted and cracked? plyer grip is an easy fix for that.
