Has anyone ever tried to cut the slide spring so that it has less tension on the throttle ? I didn't want to just cut without asking here first.
1984 Honda TRX200
1985 Yamaha 200ERN ( two of these now)
1985 Honda 250SX
1991 Suzuki LT230
2003 Honda Rancher 350ES
Try a new Cable first, you can lube old ones to the nines, but still be stiff
1985 Tri-Z-
Originally Posted by mywifeknowseverything
Exactly, unless someone switched springs or really stretched it out it shouldnt be stiff, a cable costs like $10 new through kimpex.
Scott
Just curious, Why do you want less tension in the spring?
Runners:
84 200s
05 rancher
12 rancher
when you cut springs it increases spring rates.
check cables, throtle lever,etc. than check with the carb manf. for different springs last, the spring is actually the issue with the CV Series mikuni on my 350X
RIDE SIDEWAYS![]()
got another addiction
Honda's
86 ATC 350X
T/F Survivor 06 / 07
SANDPUPPI Survivor 07 / 08
I replaced the throttle and cable with new ones and that's when it got so stiff it's hard to accelerate smoothly. I lubed it and it didn't make a difference, so I disconnected it and it's fine. I took the spring out of my other YTM and hooked it back up and it works like it's supposed too. Maybe I should just order a new spring, could have been changed at some point.
1984 Honda TRX200
1985 Honda 250SX
1991 Suzuki LT230
