Thread: Thumb throttle stiff...
    mark38090's Avatar
    mark38090 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Hawthorne, Florida
    354
    Has anyone ever tried to cut the slide spring so that it has less tension on the throttle ? I didn't want to just cut without asking here first.
    1984 Honda TRX200
    1985 Yamaha 200ERN ( two of these now)
    1985 Honda 250SX
    1991 Suzuki LT230
    2003 Honda Rancher 350ES
    Aug 2004
    Ab Canada
    4,368
    Try a new Cable first, you can lube old ones to the nines, but still be stiff
    1985 Tri-Z-
    tbirdscott's Avatar
    tbirdscott is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2007
    Prince George B.C.
    216
    Exactly, unless someone switched springs or really stretched it out it shouldnt be stiff, a cable costs like $10 new through kimpex.
    Scott
    Feb 2006
    north of buffalo
    557
    Just curious, Why do you want less tension in the spring?
    Runners:
    84 200s
    05 rancher
    12 rancher
    Jan 2005
    Wasteland Michigan
    149
    when you cut springs it increases spring rates.
    check cables, throtle lever,etc. than check with the carb manf. for different springs last, the spring is actually the issue with the CV Series mikuni on my 350X
    RIDE SIDEWAYS
    got another addiction
    Honda's
    86 ATC 350X
    T/F Survivor 06 / 07
    SANDPUPPI Survivor 07 / 08
    Sep 2005
    FL
    855
    Like GP said it will increase the tension.
    "In a society that tries to standardize thinking, individuality is not highly prized." -
    -- Alex grey
    mark38090's Avatar
    Apr 2006
    Hawthorne, Florida
    354
    I replaced the throttle and cable with new ones and that's when it got so stiff it's hard to accelerate smoothly. I lubed it and it didn't make a difference, so I disconnected it and it's fine. I took the spring out of my other YTM and hooked it back up and it works like it's supposed too. Maybe I should just order a new spring, could have been changed at some point.
    1984 Honda TRX200
    1985 Honda 250SX
    1991 Suzuki LT230
