Thread: New topend on 83 200x. Now very rich ?
    Aug 2007
    Louisiana
    10
    I just rebuilt my top end and before I was running a 108 Main and Needle in the Leanest position and ran fine with no dead spots at all .Now it stumbles bad on bottom with needle leaned out all the way and Im down to a 100 Main . It gets better every time I go down on the Main but just seems like a big jump in jets. Could the timing being off cause something like this . Ive tried adjusting the C
    DI .It helped some but not completely. Ive got a 98 and 95 Jet ordered. Thanks for any advice.
    Mike
    Nov 2006
    Tulare, California
    719
    Did you seat your rings and change the oil yet? The compression and power will increase when your rings seat.
    Current Bike:
    1985 Honda 350X
    Bikes owned:
    1984 Honda 200X
    1982 Honda 250R
    1985 Honda 350X x3
    1985 Honda 250R x2
    1985 Honda 500X
    Sep 2005
    wisconsin
    475
    Aug 2007
    Louisiana
    10
    My plugs were pretty black and wet . I also found I had the valves adjusted to tight and wasn't closing all the way . My plug does look alot better with the 100 jet and it runs strong with no poping or bogging on the top end . I have the 98 jet in and will try tommorrow.
    Sep 2005
    wisconsin
    475
    hmm mine is acting like alot like you said yours is. I too have stock jet back in with stock pipe, but I have a cam and hc piston and mine is running way to rich also, ill do what you did and go even smaller and see wha happens
    Aug 2007
    Louisiana
    10
    Incase anyone is looking at this I found the problem. My timing was off . I moved my Cam gear over 1 tooth to the right and put it back together . It ran good .I had to go back with the 110 Main get and 40 Pilot jet with Needle in the leanest position. It is unreal how much difference it made. Now it flat out gets it . No bogging any wear and will easily pull the front end in 3rd.
