Results 1 to 11 of 11
Thread: 86 Tecate tank help
    Aug 2007
    Springfield, Illinois
    6
    86 Tecate tank help
    One of the top tank bolts that holds my radiator shroud is frozen. The whole insert spins inside the tank. It has some resistance, but the person I got the bike from put a regular bolt instead of stainless steel in there. He complained a lot about the bolts coming loose on the bike, so I bet he cranked it or put lock tight on it or all the above. I was going to try and drill it, but man, one slip of the ole drill and there is a nice new vent hole in my tank.
    On a good note, I used the method on here to restore the tank, and man what a difference. The privious owner left the tank on while they spray painted the frame with silver, plus the gas cap leaks. I substituted Novus #2 and #1 plastic polishes instead of the 3m stuff, and it turned out great.
    I appreciate any help or ideas
    Scott
    Scooter
    1986 Tecate 3 (in progress)
    1986 Tri-Z Custom (in progress)
    1985 1/2 Tri-Z Stock and sweet
    1983 Yamaha 225dx still going strong, all original
    2007 Suzuki LTZ250......Her Bike
    Oct 2005
    saratoga, ny
    2,819
    i had a similar problem when i got my tank for my 86t3...i used some superglue around the nut and let it seep into the plastic around the nut area....then after letting it set up for a night, i soaked it with some pb blaster, let that soak a few hours and gave it another try, came out witha little coaxing. see if it will work for you.
    Aug 2007
    6
    86 Tecate tank help
    I may just give super glue a try. I was wondering if I pulled the brass insert out, would it tear up the tank? I think there are small flanges that keep the insert from spinning, and I was afraid they my cause more damage coming out. If I got it out, I was going to use epoxy to hold it in place.
    Super glue sounds like the best first option though.
    Thanks!!!
    Scooter
    Yes try the SG, I ruined a Banshee tank dicking around with it. Another idiot stuck a 1/4-20 bolt in it instead of a 6mmx1.0 pitch.....
    Kentucky
    2,294
    Glad I found this thread, I"m having the exact same problem with a T-3 I got a trike fest. The previous onwer installed a standard bolt in my tank. Thanks for the tip guys.
    Tionesta Trikes ATC 450R
    86 250R
    86 Tecate-3
    83 ATC 70
    85 Big Red
    81 KLT 200
    85 250SX
    Nov 2006
    southern oregon
    2,338
    man what a mess... I ruined 2 1985 kx250 tanks trying to remove the bolts... then I bought a 3rd tank on ebay... and it had spinning inserts too... good luck... let us know how the super glue works...
    2-stroke lover
    Aug 2007
    6
    86 Tecate tank help
    Got ready to try the super glue last night..............there is no gap around the insert to let the glue seep down into. I am afraid that it will just sit on top and accidentally run onto the bolt, welding it to the insert even worse. I am really curious what pulling the insert straight out of the tank would do. If it wouldn't trash the tank, I think that would be the "right" way to do it. It would be nice if I could get epoxy all around the insert.
    Does anyone have any idea what that insert looks like? Or has anyone tried popping one out? I' ll wait and see what you guys have to say before I go any further.
    Thanks!!!
    Scooter
    Quote Originally Posted by Hot Trikes View Post
    Thanks!!!
    They are round and knurled or splined and sometimes have a shoulder or the tank has a plastic shoulder that covers it, which gets beat up when you rip it out. I'd use a slide and have at it....
    The damn things should be square so there is very little possability of it coming loose.
    Aug 2007
    6
    *6 Tecate tank help
    I finally got around to trying the super glue, no dice. The insert broke free. I tried heating the area around the insert with a heat gun to pop out the insert, but I stopped pulling on it when it looked like the insert was so big it was going to break the plastic. I took a good look inside the tank, and the plastic formed around the insert is in the shape of a small light bulb. Has anyone ever popped one of these 86 Tecate inserts out? I am nervous because I only have one tank.
    Any ideas appreciated.
    Thanks!!!
    Scooter
    Dec 2003
    australia
    838
    I screwed a bolt into the spun nut and connected it to a drill. Then I spun it up until it got hot and melted the plastic, then pulled it out.
    Next up I got a new nut (could use old one if needed) and soldered steel wings on to it.
    Then i screwed a bolt into the new wingnut (I suppose you could just use a real wingnut if it was the right size) and heated it up with a blow torch. Do not apply a torch to the tank itself!
    I then pushed the new heated wingnut into the plastic tank. The hot nut melted into the plastic. I folded all the soft excess of melted plastic over the top and bobs your uncle!
    Job done
    My toys 85 KXT250A2, 85 ATC250R, 85 Tri-z 250, 06 LT-R450, 04 YFZ450S, 07 125 typhoon x 3, 06 FPV GT.
    illinois
    743
    its got be a bad thing with kawis- i looked for years for a 81-kx420 tank because of the same reasons- mine was bad though- the tanks cracked inside from the bolts spinning ,and stuff-
    i still cannot find a tank for it- i have found kdx tanks- but not a actual kx-
    talk about rare-
    i need to fix mine too-
    does the plastic weld work good enough for something like this-????
    anyone know-
