Results 1 to 3 of 3
Thread: 200x carb set ups
    Peru, IN
    121
    200x carb set ups
    I was just curious what some of you guys are running on your 200x's. When i bought mine it was on alky and had a 30mm mikuni. It came with the stock carb too and with the price of alky i put that back on. I decided to put the mikuni back on and rejet to 110 gas when i put a high comp piston in it the other day and man, I'm amazed. It pulls a lot harder mid range and top end than with the stock carb. I know Ive herd of a lot of people running xr carbs, and was just curious how those stack up against stock, or a bigger mikuni if anyone else runs one.
    84' 200x wiseco 12:1, 30mm mikuni, k&n filter, powroll cam, bassani exhaust, 6 speed trans, running on E85
    Aug 2007
    Moab, UT
    1,807
    I was running an xr carb and it worked great, I've heard a flatslide is really the ticket tho in a 28mm size. I am going to try to use a 32 flatslide on this next build up.
    Peru, IN
    121
    I wondered about the whole flat slide thing. I never realy put much thought into it because before the high compression, the bigger carb didnt seam to make a whole lot of diference. Now that it does, even better flow cant hurt . Anyone out there running a flat slide, or ran one to give some input?
