Results 16 to 30 of 62
Thread: cr-atc 125r
    Mar 2007
    Williamsport, PA/Lycoming county
    829
    how much would a chromoly swinger cost to have fabbed up? I would want one for my quad is why I asked.
    My Stable:
    2007 ARCTIC CAT DVX400
    07 Kawasaki Ninja 650R--My Baby--
    Honda 200M with a 200E engine and 200S front end- A true stump puller SOLD!
    Scars are a reminder to the old of all the dumbshit they did while young - Me
    370banshee's Avatar
    370banshee is offline Former 2strokefreak Arm chair racerAt the back of the pack
    N.W. indiana
    259
    couple hundred bucks..
    Masshole
    2,191
    Quote Originally Posted by icp4life162005 View Post
    The material isnt that much, if your able to do it yourself your looking at under 40 bux.
    Masshole
    2,191
    Well i think i got the swinger issue figured out. It is going to be offset a bit but anything short of major mods to the motor location this is what its going to have to be. For the axle carrier housing on the back of the swinger im going to pretty much duplicate the design on the 450 swinger out of aluminum and weld it to it. I attached a pic of it somewhat layed out, it will look alot better after everything gets welded and gusseted up. Im also debating laying a sheet on both the top and bottom to box it all in for added strength. I got the rear fenders figured out, they came out better than i had imagined, the stock cr seat fits right into the valleys of the plastic perfectly! Almost looks factory The fenders were originally on a 200sx quad that i had gotton for parts, a little trimming and that was it. I have a little bit of sanding on the edges to do so they dont look cut. I should have the rear part of the swinger turned and finished by this weekend, then the welding done sometime early next week.
    Attached Thumbnails Attached Thumbnails DSC02203.JPG   DSC02205.JPG   DSC02198.JPG   DSC02199.JPG   DSC02200.JPG   DSC02201.JPG
    370banshee's Avatar
    N.W. indiana
    259
    well the swinger ain't gonna be pretty but it'll work.
    Aug 2006
    huntington, ny
    192
    im trying to do the same thing with a 89' cr80
    how is it going?
    Masshole
    2,191
    Its goin, So what are you using for a rear end and forks for your 80? Lets see some pics!
    Aug 2006
    huntington, ny
    192
    i might be giving up on using the cr80 frame. the chain won't line up with the rear axle.
    Masshole
    2,191
    Quote Originally Posted by damageinc2785 View Post
    Ha, ya thats my problem, its going to be ugly but it will work!
    Masshole
    2,191
    I know i should of had the swinger done by now, its almost done, just havent really had time to go and finish it I did however make some progress, a fellow member hooked me up with the top tripple tree and front fender. I still need a few parts though like the mounting hardware for the front fender, the brake line hoop that mounts to the bottom tripple, brake line, front brake caliper. Im also trying to decide what to do for footpegs, was thinking cut the cleats off of a set from a ex or 450r or something and just welding them onto the cr pegs.
    Masshole
    2,191
    Well, i got the housing for the axle carrier, and got it tacked up to the swinger. The carrier housing came out mint! Well the swinger is gonna be a little different looking, but it will work nonetheless. Gonna get the welding finished up tomm night hopefully. Now that i got it on, i now see another issue, the ride height its a bit tall. Im not really sure what i want to do about this, i could make a new subframe, modify this one and cuss and curse about getting the airbox in the correct spot, or get a whole subframe out of like a 200x. The pro's of using the x subframe would be a grab bar, a real seat and fenders, not so sure how the air box thing will pan out with it, but its a thought. What do you guys think?
    Attached Thumbnails Attached Thumbnails DSC02223.JPG   DSC02224.JPG   DSC02225.JPG   DSC02227.JPG   DSC02229.JPG
    Mar 2004
    NE Indiana
    497
    You have to realize that this board isn't one that many visit.
    1985 Honda 250R
    1986 Yamaha Tri-z
    1984 Honda 200s
    1983 Honda 200x
    1982 Honda 200
    DarkestGKnight's Avatar
    DarkestGKnight is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2006
    Babylon
    448
    hey ive been watching *Edited**Edited* progrest on the trike but havent comment but i think it looks sweet some far!
    1982 yamaha rx50.
    2001 murray minibike with 5hp.
    fully modded goped.
    250cc 4 stroke shifter kart in the process.
    Sep 2007
    British Columbia, Canada
    818
    Thats looking really good.
    For the height, is there any way you could tilt the shock forward to drop the height a bit?
    On my 200X, I tilted the shock back for a little extra height, and all I had to do was make a couple of new mounts. Not sure if it would work in your case, but it's a thought.
    [b]'83 200X-
    White/Blue:
    The 2 stroke 200X
    Vids:http://youtube.com/watch?v=HwDqUVM9jOo
  15. #30
    Aug 2005
    HI
    1,575
    I was thinking about putting a CR125 in a 200x. I like this route a whole lot better.
    Sorry about all us not responding.
    That swinger looks really trick! I would keep the ride height. I think it will work out when you sit on it?
    Rest in peace Rex Carlson
