1983 200e with verry weak spark, tried a cdi box worked , then didn't after i tried to restart, also tried a coil...any ideas??? i'm at my whits end![]()
Clean all the Connection's & Ground !
Make sure the Timming is correct , Check & adjust the Valves to spec.
Clean the Air filter , Buy a New Plug , Fresh Fuel ...
Takes time to figure it out ....
I've seen the coil behind the stator go bad on the hondas alot in the past. You can get them here fairly cheap: http://www.hyperparts.com/wc.dll?ctw...1~part~H130450
