Thread: Are honda 85 200s and 200m front forks the same
    svo58 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2004
    clifton park,saratoga county,N.Y.
    166
    Can anyone tell me if the 200s and 200m front forks are the same size from inner fork to fork .I know the 200s uses a 22-11-8 tire and rim and the 200m uses 25-12-9 tire and rim ,but I want to know are they the same size or are there any difference in them .Any info would be great ,thanks ........svo58
    84 big red 200es with speedo
    84 70cc ATC- new top end ,rear rack, head light and tail light
    85 250es big red
    85 250sx
    Jul 2006
    western ny
    3,366
    i put a 200m front end on a 200s . the 200m front end is wider the the 200s by about an inch or 2 on each side.
    GIT IT RAAAGGGGG !!!!
    Mar 2007
    Williamsport, PA/Lycoming county
    829
    I have 200S forks on my 200M right now. 200M 200E 200S and 200standard version will all interchange with each other. you just have to have the triples to go with the forks.
    My Stable:
    2007 ARCTIC CAT DVX400
    07 Kawasaki Ninja 650R--My Baby--
    Honda 200M with a 200E engine and 200S front end- A true stump puller SOLD!
    Scars are a reminder to the old of all the dumbshit they did while young - Me
    Nov 2002
    Kirkville, NY
    3,831
    No, they are not the same. The 200m is wider, you can swap out the two but you have to use everything (tripple, shocks, hub, axle, ect.).
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Jul 2006
    western ny
    3,366
    Quote Originally Posted by thefox View Post
    its true. i did it with my old 200s. i went to use a 200s axle and shims and hub. it was a no go. the 200m front end is wider. if you want a 200m front end you will need the whole dam front end. rite down to the brake hub assembly. unless you are willing to rig it up.
