Results 1 to 15 of 25
Thread: 84 250 R hubs do NOT fit 200X rear wheels, what does?
    Jan 2005
    Slatington PA
    4,372
    I was told on here by Jason I think (could be wrong) that R hubs will fit 200X wheels except for grinding a small bump at each spoke of R hub so the hub fits flush, which is correct BUT the studs on R are smaller diameter so they do not fit proper and have back and fourth play so I need larger diameter studs.
    I guess maybe the older 200X's had smaller studs like my R and I have 86/87 wheels then ?
    Will a hub from 200X or a 300 or 400EX that has same wheels also I think, fit spline wise on a 84 R axle ?
    Jul 2006
    blaster/tri-z hubs/banshee/200x/250ex/300ex/400ex all fit 250ex-400ex will give you some extra width, that is what I have on my 300
    Jan 2005
    Slatington PA
    4,372
    " all fit 250ex-400ex " ........you mean 250R, don't you ?
    I'm confused, what exact rear wheels & hubs do you have ? Same wheels as me ?
    Jul 2006
    I ment all those hubs fit COMMA 250ex-400ex will give you etc etc.....
    Jan 2005
    Slatington PA
    4,372
    I don't want any extra width on the account of where I park it in the garage, if it is any wider, it will interfear with parking car. So what would I be after then, 86/87 200X hubs ?
    What about the 350 X, will they fit ?
    85-85 250R ?
    450R quad ?
    Jun 2003
    englishtown NJ
    2,676
    yes, they do fit, the 81-82 250rs used a smaller diameter stud. I have 84 ones on mine, they fit the wheels.
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by deathman53 View Post
    On your what ? I don't know what trike you have ?
    So 81 thru 84 are of all the same small diameter ?
    "They" as in all that I mentioned ? ........ What about the 350 X, will they fit ?
    85-85 250R ?
    450R quad ?
    Jun 2003
    englishtown NJ
    2,676
    I have a 86 200x, they fit my wheels from all honda'a w/ 4/110. Basically 83/84 250r, 83-87 200x, 400ex, 450r, I think 300ex all share the same bolt pattern and spline on the axle. 81-82 250r's have a smaller diameter stud, however the hubs will fit on most honda 4/110 models. 350x hubs won't fit, those will fit on 85-89 250r's. If I were you, I'd get 400ex hubs, they can be gotten very cheap or take off 450r hubs. I also have liquid cooled 250r's, one of them has 350x hubs on it.
    Newfoundland
    5,280
    Find yourself some "acorn" style lug nuts. That will take the gap and center your rims with no play.
    Yes, sure looks like you just need the tapered style lug nuts like a 250R has and not the flange nut of other years and styles. Is it a 10MM diameter stud??
    Jun 2003
    englishtown NJ
    2,676
    10mm 1.25 pitch, I use the tapered nuts, but spin them around so the flat side holds the rim on, this way in-case I need another rim, I can use any honda rim, tapered or non-tapered.
    Jan 2005
    Slatington PA
    4,372
    Thanks a lot guys, the tapered nuts is a good idea but I do prefer a larger stud with other hubs.
    Where do I find metric acorn/taperd nuts ?
    So any of these hubs would work then ? .........
    (and if so can I find the correct nuts where you recommend finding the other ones)
    http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=015
    http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=008
    http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=007
    Eastern Long Island
    1,688
    Both the hubs you linked will add about 1" width per side. I have 83-85 200x hubs on my 300R with the tapered lugs and they hold up fine. The early 200x hubs wont add any width but as you stated, you need to grind off the little nub to make them work.
    Lots O Trikes!!!!!
    Quote Originally Posted by Huffa View Post
    So these hubs would work then .........
    Maybe I'm a bit confused... Huffa, are your studs 10mm?? If they are then they are supposed to run the tapered nuts when running any type of rim with the pressed in insert. Which, it's hole is quite a bit larger than the 10mm stock stud. If your studs are 8mm then they just aren't right for your setup.
    Aftermarket and other rims have a hole just a hair bigger than the stud and use a washer and a flanged nut.
    The tapered nuts are used on any of the performance ATC's as they hold better than a flat washer and flanged nut. There is no chance of any play developing in a tapered OEM style setup.
    springville, PA
    6,185
    huffa if you want larger studs knock out the stockers, drill the hub out, and put larger ones in.
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
