Results 1 to 15 of 16
Thread: chain?????
    new brunswick
    39
    chain?????
    does anyone know why a chaine would continuasly slip. and yes it is tight or so i think i could not get it any tighter.
    Jan 2005
    RI
    2,530
    get new sprockets and a new chain to go with it...
    mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    new brunswick
    39
    they are new
    Ontario, CANADA
    4,538
    Got a pic of the chain? This would help us..
    on the trike
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Aug 2002
    NY
    2,652
    Something may be bent a little to make it ride poorly.Otherwise I was thinking the same thing about the sprockets.
    Is the chain on backwards????
    new brunswick
    39
    unfortunatly i don't have a camra. but it is only when it is adding power if you are already moving it aint so bad but still seems to slip from time to time.
    Jul 2006
    western ny
    3,366
    hmmm are you sure its skipping ? i ask because when i had my chain on to tight it sounded like it was skipping but it was actually too tight and made a crunch clank sound (like a skipping chain would)
    GIT IT RAAAGGGGG !!!!
    new brunswick
    39
    i don't think it is too tight because there is still a little slak in it and when i hear the noise it slows down until it stops then it continus on and so on with no end.
    and if it was too tight why would it sound like it saw skiping
    Apr 2006
    PA
    1,464
    Are the splines stripped where the front sprocket mounts? A chain wouldnt just slip around the sprocket if there brand new. Even a highly worn sprocket dosent slide around the chain.
    new brunswick
    39
    no the splines are good
    Jun 2006
    Willow, Alaska
    1,337
    What kind of trike is this on? And what do you mean by slipping, does the chain fall off or does it feel like the chain is moving but not pulling the sprocket? Also something to check are 1) Is the hub for the sprocket on the axle stripped? and 2) If this is a suspended trike, is your chain loose or tight enough? If it is suspended, when no weight is on the trike, the chain should have some slack, but the more weight is put on it, the more the chain should tighten up, but still have a little slack when the shock is fully compressed. HTH
    -Nick
    1988 Chevy Silverado 5.9L Cummins : 1986 ATC250R : 2012 Polaris RZR 570 :
    98% of Americans say 'OH $#!T!!' before going into a ditch on an icy road. The other 2% are Alaskans, and they say 'Here, hold my beer and watch this!!'
    new brunswick
    39
    not a suspension bike it just seems as though it is too lose but not the sproket rotats bet the chain does not. and i have no idea what it is. it say commuter. but i don't know who makes them.
    Jun 2006
    Willow, Alaska
    1,337
    Does it have a centrifugal clutch on the front? Like a Briggs and Stratton style motor? If so, that might be slipping (and giving the appearance of the sprocket on the clutch rotating), otherwise, unless your sprocket is completly round with no teeth I cant think of anything else it might be...
    This is the kind of clutch Im talking about.
    -Nick
    Apr 2006
    PA
    1,464
    I forgot about that, Its probably your clutch. On my X it seemed like it wasnt moving and was revving up. I replaced the clutch and its perfect now.
    These recent barely understandable posts from newbys are driving me nuts....
