Results 1 to 3 of 3
Thread: Atc 90 and Atc 110 camshafts the same?
    Rennat_2006's Avatar
    Rennat_2006 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2004
    194
    Alright i have been told by one website that sold ATC 90 performance camshafts that his cams would not work with my 110. Im looking at one on a website right now that says it fits Atc90/110 so who should i believe in this case.
    Can anybody help me out please!
    thank you
    -1983 Honda ATC110-
    Brand new topend using. Performance cam and some porting/polishing.
    Should be good for another 24 years now!
    -1991 KTM 540-
    Piston turned into grenade inside motor ammit
    -1996 KTM 550-
    Midway through COMPLETE rebuild
    -1997 Honda Cr80-
    Spun crank bearing on trans side ammit
    Feb 2003
    Australia
    927
    They will work in either machine. If you put a CDI 110 cam in a 90, you have to remove a small piece off the advancer journal but not if you do it the other way around. A longer bolt may be needed.
    Mar 2004
    194
    Thank you!
    It will be for my 1983 110 which is CDI so when i call the place the sells the camshafts tommorow i will make sure to tell them the year and CDI.
    Thanks again!
    -1983 Honda ATC110-
    -1991 KTM 540-
    -1996 KTM 550-
    -1997 Honda Cr80-
