If the splines are stripped on the shifter shaft what can be done other than replacing the shaft? Thanks
WELD IT BUT DONT GET IT REALLY HOT OR YOU WILL MELT THE SEAL
Go to the store and buy alot of duck tape and wrap that trailprotrailprotrailprotrailpro all over the place..lol!
j/k, i had mine welded with brass..so its easy to get off if you ever need to
3 racing gokart's
02 Kawasaki ultra 150 jetski
02 kawasaki 1100 DI jetski
dont weld it. put the shifter on in the right place and tighten it down. now drill a hole in the from the side, half on the shifter half on the shaft. tap the hole and insert a bolt.
it is more complicated then welding but it is removable and it wont mess up the seal due to the heat..
chris
You have 2 options, Replace the shaft or a yyz has said weld it on, this needs to be done with a mig welder, make sure the lever is in the right place and clamp some vise-grips between the lever and engine as this takes away a lot of heat, if you get it too hot the seal will be damaged and it will leak oil, then you have to put in a new one and you might as well replace the shaft whilst you're in there! dowse the whole shaft with water after welding to cool it completly then your seal should survive!
I'm guessing you have a 110, as this is a very common fault
Nat
1979 Suzuki TS100
1984 ATC70, Broke
1984 ATC110, Repainted and Rebored.
1990 Suzuki SJ410
Unsuspended Antics.
Thanks everyone. I knew you guys would know what to do. Hey cmracer15 is that A Phantom in your Photo? Looks like Banshee body work.
it might be stripped but maybe a little more pinch might get it tight enough to hold up to normal use.
to do that i have put lever in vise and using a hack saw cut a piece out of where the bolt draws the crack together ( to pinch or tighten)
i'm having a hard time describing this i know,,, lol
i cut the part the bolt first goes thru,,, not the threaded side.
what i am attenpting to say (rather stinking poorly) is if you can increase the gap in the middle of the shifter lever, iy will be able to draw down tighter (that's better).
you can also clean up the threads on both pieces with a triangle file b-4 tighting on to give it better grip. then if that don't work you ain't out nothing but time.
john
Mike, no thats my new 03 comet challenger. I bout the body from therral (i think thats how u spell it) racing. Its an awsum looking metalic blue. And since my dads buisness deals through k&n alot, i got them to hook me up with a little bit of sponcer money and free filters and stuff...and all they asked was i put those stickers on the karts somewhere...i actualy tink it looks pretty nice how i have it..for some reason when i resized that pic it made it look like crap. Ill get my dads digi camera out and shoot a few more pics of the karts i have.. do you race? what state you in?
3 racing gokart's
I have 4 boys and they have all raced. My oldest has been doing it for about 8 years. Mostly dirt speedway but we run the sprint nationals if there close. We live in North Texas but have raced from Daytona to The IKF Nationals in Oregon 1996. My oldest son has moved on to other things and as of now no one is racing Karts from our house. Have you run at Daytona?
do what basket said. you dont have any welding to do, so you wont ruin the seals. also, it makes it stay for good, and you can remove it when you want to.
My Rides
Yamaha 225 DR For Sale Soon
Yamaha 200E
Honda 110 Need parts? PM me! They're cheap!
Trikes are fun, trikes are fast. They make everyday a pure blast!
it really is the best fix. welding is easier but it can really cause trouble down the road.Originally Posted by plkmonster2
depending on how striped it is you can put an tin can over the splines and tighten it down then it should work for a while if not just weld it you can always grind it off
