sorry well i got everthingi hope to install this beast back together my q is when you install the bearings and seal in for the axles... should the seals be right up to the bearing or at the end of the hub...thx
if there at the end of the hub you dont get that build up of crap in that lip of the Carrier. Some bikes have little plastic dust seals on the hubs witch require to set them in a little.good luck
thx.......
