Everything I own has to have a modified air intake. My truck, quad, and trike have all went under the knife.
F-250 - K&N Fuel Injection Performance air intake with a little something extra or should I say less. I cut a hole in the radiator shroud so air will go straight to the filter. Almost as good as ram air.
Honda 4X4 - I wanted to keep the snorkel intact so i remmed out the opening at the top with a Dremel and cut off the pipe right after it goes into the air box.
Yamaha Trimoto - Removed the snorkel hose, it was so restrictive that it died once when the wind was blowing really hard. I don't plan on having it in any deep water so I think I'll make a bigger hole in the air box.
If anybody else has the same problem as me, it is someone in this forum. Do things like this really help or is it all in my head?
