Originally Posted by
Wi200x
Just got back from running the R at a local riding area that only allowed 1 & 2nd gear half throttle and once in awhile 3rd gear. Surged real bad when letting off the throttle-ran good otherwise. Pulled the plug and inspected it when I got home and it looks perfect. Tan color and no signs of detonation. Haven't tried the BelRay oil yet as I haven't recieved it yet.
Gee, that sure sounds like a fun riding area!! LOL...
Anyhow, you said air screw and I thought the R's had a fuel screw? In other words turning it out would let in more fuel.
Maybe I'm crazy (or just wrong) but I thought air screws worked opposite from fuel screws.... just make sure your turning it the right way to get the desired result you want.
I'd make sure that screw has a good oring and spray carb cleaner around the boots and intake while it's running to check for leaks. The one bike I had crazy surges with had a piece of the old reed gasket under the new one and it was letting outside air into the mix....
