http://cgi.ebay.com/ebaymotors/30MM-...QQcmdZViewItem
is this a good carb upgrade for a 85 200x??
'86 200x
Ya,if you port and polish the head,change lift and duration,performance muffler and head pipe.
My old 1985 250R http://www.flickr.com/photos/24898661@N07/show/
Feedback http://www.3wheelerworldforums.com/s...feed+back+edog
Currently trikeless
30mm sounds kind of big to me, are you doing a lot of other motor mods?
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
thats huge, its 6mm bigger than the stock carb! I have a 27mm on mine, it definetly noticable. Better top end, somewhat less bottom end.
So i should go with the 27mm??? are these good carbs to use though?
thanks for all the help so far
'86 200x
Do it. Its the same size as a standard XR200 carb, over here anyway
so i could get the carb and then whatever is like 1 higher jet than stock xr200 and put in there?
'86 200x
