GT80 (enduro80) oil pump.
Ok i just took the right side of the bottom end case off to replace my kickstart shaft and i also installed a new oil pump.There are two oil lines going into the fuel pump(big one and a small one).I hooked up the big one to the pump but i didn't hook up the small one.The small line goes from the fuel pump to the intake manifold (carb manifold).The small line has some sort of white oil inside it and the pump.I just wanted to know what this line was for.I am also running it on 32:1 premix and injection.I haven't fouled a plug yet.
is it moisture in the oil?
block it off- -- i run my 420-- 32:1 it works good- klotz oil
now i don't think there is moisture in the oil lol probably the oil from when they made the bike. If there was mositure in the oil it would be really runny and diluted.
//ArrowChat Integreation Code
