WOW, everybody who told me how crappy a job this is, you weren't kidding!![]()
Anyway the rear end finally gave out on my R, lasted a while though guess I can't complain..... It gave out on the trails. My chain fell right off, it got jammed between the shifter and the frame. Thank christ it didn't crack my case, I was just putting. So after the nightmare of getting it homeI inspected. The bearing on the sprocket side must have just self destructed!!! If you grabbed the grab bar the bike had about 1in of play on the sprocket side!!!
Wonder why my chain came off?? lol
So I began tearing into it today, dreading this job because everybody who does it says it sucks, they're right. The axle pulled through while the carrier stayed in the swinger. I tapped it out with a dead blow. Next I got the distance collar out (round tube) and it had a broken ring on the sprocket side (the thick silver ring in the pics). i imagine that's the dust seal (#25). I never found the bearing on the sprocket side, it must have blown apart and just escaped out the side??
Here's the link to the bike bandit service manuel. The diagram is under swingarm...... http://houseofmotorcycles.bikebandit...0R/1985/173401
pretty sure I'll need two of part number 22 and 24. Might replace some other seals while I have it aprt too.
all my parts
bearings and dust seal are still together on the brake side....
Somebody please tell me WTF this ring thing is? It obviously got raped because it was between the sprocket and swinger after the blowout. It's not in the service manual? It has some rubber on it if that helps....
sprocket side bearing and seal are out
Somebody who has done this before let me know what to do next and how to do it!!! BTW I soaked the brake side bearing and seal in PB blaster, just letting it sit before I pound it out....
Thank you so much!!!! -Devin
