Hi everybody, a buddy gave me an old kawi that we found at the dump a while back 'cause he got tired of it sitt'n around. I have no idea what exactly it is. The fender says 250 & on the steering head it says KLT 250C I believe. There is no plastics seat etc. I don't know alot about three wheelers but have worked on/played with/modified bikes & cars as long as I can remember. Here's my problem. I've started making a wiring harness from scratch & have got power to the fuel pump & the carb has gas in it. I've also got power to both lights which work & a starter button rigged & the motor spins fine. Now all I need is fire. there are two black wires that come from the front left hand side of the engine that plug into the black box, there are two other wires that go to the coil & I know they're right cause that was pretty muck the only thing hooked up. what do I do with the last two wires from the black box? There's six total, two to the engine (a pickup of somesort I'm think'n?) Then the two to the coil. The only two I don't know where goes is a yellow/red & a back yellow (which I'm assuming is grround.) I've looked for wiring schematics at bikebandit, here, kawasaki & can't find anything for what I need, any help is greatly appreciated!
no man but for real thats messed up big time. on any normal set up usually the "hot" wire coming off the ignition coil on the stator goes to a cdi box or the ignition coil on the frame. dam thats messed up. this is why i stick with honda.
