Is it "slipping" or downshifting??
I have found 90% of all gear shift problems are NOT inside the center case. Many times it is merely the shifting mechanism, springs, dowel pins, studs or other related parts. You'll have to get a manual and look at it before you tear into it. Then remove the correct side case because some of these mechanisms are in the left case and some the right. Tear it off, and lift up the rear wheels and spin the tranny through the rear wheels while shifting to see whats up.
Hopefully it is an external case issue.....
People sell machines over simple overlooked problems like this. I buy em, tighten a bolt an triple my investment
