Results 1 to 13 of 13
Thread: A+ 70 frame measurments
    Frewsburg NY
    1,169
    If anyone on the boards has a A+ frame I could use some measurments. Do they use stock frame tube and then bend. What iam looking for is were the bend starts and if anyone knows the angle. I have a few 70 frames and I am trying to make a jig to make suspension 70's.
    Baltimore, MD
    6,088
    The A+ frame is a custom tube frame. I have one that I can try and measure later, at work right now. Heck, if you wanted to come to Baltimore, you could measure it up to your hearts content, and my PK racing frame also if you want. The suspesnsion frames don't really use any parts of the stock frame. If you do a search for suspension 70, you will see my pictures of the 2 rolling frames. If you want to come down, just give me a heads up and a couple days notice to make sure I'm not working, shift work sucks sometime.
    Lancaster, PA
    1,738
    I will take some pics today, I have my A+ frame tore down right now.
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Frewsburg NY
    1,169
    Measure to see if the length of the tube is different than a stock tube. I was thinking I could just bend the stock tube to be like the suspension 70
    Lancaster, PA
    1,738
    first pic is a stock 70 frame( alittle bent) 2nd is compared to a chinese pit bike frame
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    and many more!!!
    Blue Line Graphics
    Frewsburg NY
    1,169
    Well iam going to cut of the welds tonight so only thing I have left is the tube. I guess trail and error will be this projects name. I will put it in bender until it looks close i guess. Then on to the swinger, cut and shorten one that I will use. Iam going to try and use bearing carrier from stock and mod to 350 or 250 swinger, not sure how that will work but I will find out tonight.
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    the stock tube is WAY to thin and WEAK TO WASTE TIME MESSING WITH ,,, there is no comparison in wall thickness . stock 70's bend very easy ,,, i used a stocker to build my first one too,,, its long gone and BENT!!
    Nov 2002
    Kirkville, NY
    3,831
    I agree, stockers tend to do this....
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Jun 2002
    Mississippi
    2,552
    nice rake job on that one!!!
    83 ATC70
    85 ATC70
    85 200x vintage racer
    86 500r
    Lots of parts
    My 500R
    Frewsburg NY
    1,169
    Well I have already started to cut up the frame. I know they are weak but I am just doing this to make a jig more or less. If everything turns out well I would start a frame from scratch.
    Apr 2004
    Brigham, Québec, Canada
    1,528
    Quote Originally Posted by thefox View Post
    Nice OCC style atc 70 chopper
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Nov 2002
    Kirkville, NY
    3,831
    Quote Originally Posted by 200x Basket View Post
    Well we have all seen machines with the engine as a stress member of the frame, now how about using the gas tank! The tank was binding up between the rear bolt and the front mounts, that was all that kept the engine from digging in the ground. Let’s just say I got a little surprise when I landed the wheelie .
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Baltimore, MD
    6,088
    As far as the frame length goes, you might think of lengthening it a couple of inches so the hot engine parts will definitely not touch the fender.
