hey guys, i'm wondering whats the lowest psi the motor will still run. the reason i ask is; my motor alway has kicked over too easily. i know it needs new bore @ piston /rings. but still runs great, but probably about to blow i assume because have run 2 set of pistons without rebore.- i know, not smart- but funds were low. i was curious to see what my reading was so i checked. shocked! 1st kick 20 psi, 2nd 40, 3rd 60, 4th 80, 5th 90, 6th 115, -well- it took me over 10 kicks to reach 155 psi. - (below minimum). can it really be this bad? bike runs fine. starts always with about 3 kicks. a little piston slap, but not too bad. is my gauge bad? anyone have similar situation ever? --------------------oh yeah, i did hold throttle wide open and choke was off. also,i would like to know how many kicks should you be up to for max comp?
