Results 1 to 10 of 10
Thread: 250R Silencer inlet size
    Sep 2007
    British Columbia, Canada
    818
    Anyone know the size of the inlet on the 85-87 250R silencer?
    I need a new silencer for my 2 stroke X project and I'm wondering if the FMF Power Core 2 made for the 250R will work, because I know I'm not going to be able to find one specifically for PE pipe.
    [b]'83 200X-
    White/Blue:
    The 2 stroke 200X
    Vids:http://youtube.com/watch?v=HwDqUVM9jOo
    Utah
    644
    On an FMF silencer (not the powercore, just a regular fmf), I measured the tip of the silencer inlet pipe where it slides into the larger exhaust tip of the sectional pipe. The O.D. is about 31mm and the I.D. is about 29mm.
    A few wheelers, + an
    '73 Honda 49cc Mini Trail
    '85 200 Big WHEEL
    "Despite the cost of living, its still popular."
    Sep 2007
    818
    29mm is about 1 1/8th inch right? If it is, then it'll work.
    Thanks for the help!
    [b]'83 200X-
    White/Blue:
    The 2 stroke 200X
    Utah
    644
    The actual measurement I got for the outer diameter was 1.25 inches, and the inner was like 1.14 inches. Yes, very close as 1/8" is .125. If you need it as persise as a tenth or hundreth of an inch, I will have to measure the id again. But that is extremely close.
    Edit- I think I have a little carbon build-up I would need to clean to get a more accurate i.d. measurement.
    '85 200 Big WHEEL
    Sep 2007
    818
    Quote Originally Posted by Rustytinhorn View Post
    The actual measurement I got for the outer diameter was 1.25 inches, and the inner was like 1.14 inches. If you need it as persise as a tenth or hundreth of an inch, I will have to measure the id again. But that is extremely close.
    Edit- I think I have a little carbon build-up.
    Don't worry about the percise measurement. I just wanted to make sure it was relatively close, so that I didn't buy it and have it be half an inch too large or something like that. If it's just a few mm's off, I won't be too worried.
    Thanks again.
    [b]'83 200X-
    White/Blue:
    The 2 stroke 200X
    Utah
    644
    Hey ya, good luck with it. I would hate to have you order the parts thinking they would fit, only to find out my measurement was different from the newer exhaust parts.
    '85 200 Big WHEEL
    Sep 2007
    818
    I don't see them being much different, since they're for same machine.
    Hell, even if they are somehow different theres always a way to make it work!
    [b]'83 200X-
    White/Blue:
    The 2 stroke 200X
    Utah
    644
    Just to be safe, that was an '85 Atc250r exhaust I measured. Not the quad.
    '85 200 Big WHEEL
    Utah
    644
    Quote Originally Posted by TwoHundredEx View Post
    Haha, I guess thats true.
    Good luck.
    '85 200 Big WHEEL
    Sep 2007
    818
    Thats exactly what I wanted. And just to be safe on my end, I just double checked to make sure that I wasn't looking at the TRX silencer but it specifically says ATC250R.
    [b]'83 200X-
    White/Blue:
    The 2 stroke 200X
