Results 1 to 10 of 10
Thread: 2 stroke Carb on a 4 stroke??
    McDerry is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Maine
    440
    I don't see any particular reason it couldnt be done if it was jetted right.
    Other then now choke, but having an enrichment passage instead is there anything that in particular wouldnt let a person run one.
    Reasoning is I have a KLT160a chassis in hard shape I found at the local dump, with some compression a cdi, a coil, and the vast majority of the wiring. The exciter coil has 187 ohms which is about where my running hondas are at.
    Now it was missing a carb but has the intake boot. I also happen to have a old CR80carb as an extra for my lil dirtbike and it fits the intake on the KLT.
    illinois
    743
    what a 2stroke 80 carb on a 200x?-lol
    Jun 2006
    Willow, Alaska
    1,337
    Generally its not a good idea to switch between 2 stroke carbs and 4 stroke carbs. Will the engine run? Yes, more then likely it will, but the reason for not wanting to use a different carb is that the 2 strokes are jetted differently for one, and two, they have a different air mixture screw. (I think thats the name,, im tired so bear with me if its not ) It can cause your motor to run really rich or really lean, and it will be a PITA to get jetted correctly. If you really arent concerned about the right carb, find an intake boot that will fit the motor and find a carb similar to the one thats meant for the bike. Other then that, KLTs are getting parted all the time, it should be really easy to find one for cheap.
    -Nick
    1988 Chevy Silverado 5.9L Cummins : 1986 ATC250R : 2012 Polaris RZR 570 :
    98% of Americans say 'OH $#!T!!' before going into a ditch on an icy road. The other 2% are Alaskans, and they say 'Here, hold my beer and watch this!!'
    Jul 2006
    western ny
    3,366
    ive done allot of diff types of carbs and nick my friend you hit it rite on the head. i have never put a 2 stroke carb on a 4 stroke but ive bin looking at doing it. the only thing i see that needs to be done is to rejet the carb. but as i said...ive never done it before.
    GIT IT RAAAGGGGG !!!!
    springville, PA
    6,185
    One of my SXs came with an air fooler carb on it . I guess they tried to rejet but were retarded because they put a 156 for a main . Anyway it ran but needed rejetting bad
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    illinois
    743
    yea- 4 strokers- some have air jets in the air horn that are rejettable-,needle jets,mains,depends on if its a cv carb or regular round slide / flat slide carb ect...
    Nightbiker07's Avatar
    Nightbiker07 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2007
    Toledo, Ohio
    382
    you also have to remember how 2 and 4 strokes work.
    a 4 stroke sucks the air through the carb, picking up the air and atomizing the fuel with the air on the intake stroke.
    The fuel is pressurized by the piston downstroke in a 2 stroke because there is fuel in the crankcase, and therefore forces it into the upper part of the cylinder, but almost half the air that goes into the cylinder comes from the exhaust. Heres a good graphical representation:
    http://en.wikipedia.org/wiki/2_stroke
    Yes, it could work, but it will run like total garbage.
    Apr 2006
    Maine
    440
    The scavenging effect should affect how the carb works, its still gonna atomize the fuel into the air when theres an upstroke of the piston.
    Tryed it today.
    Used a keihin 61A (its either a 26mm or a 28MM) and it fires and runs
    Sep 2007
    Toledo, Ohio
    382
    Quote Originally Posted by McDerry View Post
    TRIED it today.
    but how well did it run?
    Apr 2006
    Maine
    440
    high idle was the only thing I could see as an issue.
