Thread: 350x chain help... missing parts???
    Sep 2007
    Overland Park, KS
    11
    I am new to the board. I just bought a 1986 350x and I am trying to get everything adjusted properly. It is all original and in very good shape. I went to try to adjust the chain due to it having way too much slack, and I think I found that it is missing the adjustment screw. Am I correct that it is adjusted by loosening the two allen head bolts on the end of the bearing carrier of the swing arm then adjusting using a bolt that should be in the bottom center of the swing arm axle carrier? For my bike that hole is empty but it does not have crap in the hole and the axle moves free without any noises. If I am correct does anyone have any idea where I can find a replacement bolt for that hole? I tried the search method for the forum and was unsuccessful. Thanks for the help!
    I am trying to figure out how to get pictures of the problem downloaded and shrunk to the proper size. If I figure it out then I will post them later. Thanks again!!
    1987 CR125R (sold)
    1986 350x
    2003 SV1000-N
    Ride it like you stole it!!!
    Jan 2005
    RI
    2,530
    you loosen those two allen bolts, then you have to use a tool on teh carrier...Look for some teeth on there, and bring it towards you to tighten the chain.
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Apr 2005
    Elrod, IN (near Milan)
    114
    is correct. Just to the right of the sprocket you will see a large disc with tabs going all the way around it. This is actually part of the bearing carrier. You will need a spanner wrench to safely tighten it. Without one, you risk breaking off the ears on the bearing carrier like the idiot before me did on my 350x. Not cheap to replace. Bike shops sell the spanner wrenches, although they're not real cheap - generally $25 - $35.
    I'M GETTING TOO OLD. IT TAKES ME AN HOUR AND A HALF JUST TO WATCH 60 MINUTES.
    '85 Big Red 250es (Beer truck)
    '85 350x
    '85 250r
    '84 ATC70
    '01 Yamaha Warrior 350
    '05 Honda Recon 250
    Always looking for more!!!
    '05, '06, '07 TF survivor. Looking forward to '08!
    Sep 2007
    Overland Park, KS
    11
    Thanks for the help DeePa! I got it tightened easily with your instructions. I appreciate it. Nothing broke and it seems to be working great. It is the original chain and sprockets so I am curious as to how much longer it will last. Thanks again!
    1987 CR125R (sold)
    1986 350x
    2003 SV1000-N
    As posted above - If it's an 86 and it has the right carrier then the same allen wrench fits the notches in the carrier. If it doesn't turn real easy then take it apart, change the orings and grease it up. That center bolt underneath is a stopper and allows the carrier to only rotate so far.
