Results 1 to 12 of 12
Thread: Got a 500!
    ovhonda1's Avatar
    ovhonda1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2005
    Louisville, KY
    369
    Got a 500!
    Bought a 2000 500 Scrambler 4x4 for the GF to ride and broke the drive belt the first ride. Guy said it was worn. These things easy to install? What other things do I need to look for on this bike? What is important on maintenance and what's not? All you Polaris riders out there please give me your .02 worth. Thanks!
    Mar 2007
    Williamsport, PA/Lycoming county
    829
    sell it and but a......... well..... anything else really.
    My Stable:
    2007 ARCTIC CAT DVX400
    07 Kawasaki Ninja 650R--My Baby--
    Honda 200M with a 200E engine and 200S front end- A true stump puller SOLD!
    Scars are a reminder to the old of all the dumbshit they did while young - Me
    Sep 2005
    Lipetsk, Russia
    2,824
    Quote Originally Posted by icp4life162005 View Post
    Haha not really helpful but TRUE.
    I don't think the belt should be that much trouble to change, probably just a cover you unbolt and slide the new belt onto the clutches... don't tear the gasket!
    I'm back in the USSR...
    Dec 2002
    Kansas
    2,387
    Easy as can be to change. Take less then an hour if you have never done it. No gaskets to tear. The belt is kinda pricey at near $50. We have a 1998 500 4x4 scrambler and a broken belt is the only breakdown we have ever had in 4 years. Don't let these "if its not a honda its junk" guys scare you. When you change the belt I was also told to rub my hands against the sheeves to make sure no rocks have scratched them up.
    I had the RIGHT to remain silent, I didn't have the ability!
    ovhonda1's Avatar
    Sep 2005
    Louisville, KY
    369
    thanks for the HELPFUL info smokinwrench.
    Mar 2007
    829
    Hey I AM NOT A ' If its not a honda its JUNK!' guy............., only if its poo-laris's.
    My Stable:
    Groundworx's Avatar
    Groundworx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Tuttle Oklahoma
    421
    Quote Originally Posted by smokinwrench View Post
    Do you have to keep the tension on the belts adjusted? I have never messed with one, but I thought I heard that before.
    Many quads for sale. 400EXs, Z400, 450s ect.
    May 2002
    Southeastern Wisconsin
    3,658
    Tension is not an issue. Just slip on the belt and the machine will do the rest. For a long time now I've been using Dayco belts. They cost less then OEM and last just as long.
    Groundworx's Avatar
    Tuttle Oklahoma
    421
    Cool, like I said, I have never messed with one before. I thought someone told me that one time. I have looked at the Polaris quads at the local dealer and I like the big utility quads they make. They have nice sticker $$ too though. I haven't heard anything bad about the Polaris though.
    Aug 2004
    Ab Canada
    4,368
    Check out the front motor mount on it, they like to break, throws the motor/ clutch out of alignment and will cause premature belt failure/ creeping, run your hand on the sheaves of the primary, make sure its not grooved/crack', and change the oil regularly...or you will eat a cam,, polaris arnt bad machines, just got to stay on top of the maintnece or they turn into money pits. also if the belt came completly apart, make sure to shake the heck outa the intake tube for the cover to get all the little bits out.
    1985 Tri-Z-
    storm_impulse is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2007
    west virginia
    291
    the only thing i have ever seen that is bad about a poolaris is, my buddy has a 500 sportsman and he was doing 55 and the front cv axel pulled outta the tranny causing him to crash into a tree and damn near killing him. thats all.
    1986 atc 250R. needing alot of parts. winter projet!
    1988 lt 250r quadracer. building now.
    Sep 2005
    Lipetsk, Russia
    2,824
    Quote Originally Posted by storm_impulse View Post
    Oh, is that it?!
