Results 1 to 13 of 13
Thread: Setting timing from scratch
    VenomRS4 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2007
    Massachusetts
    418
    Im thinking about picking up a 185s from a board member. All it needs to run is for the timing chain to be hooked back up. I guess it fell down into the motor. I figured put the piston at TDC and close the valves then hook the chain back up. But I have a feeling its more complicated than that. (btw, im used to 2 strokes, ive never done internal work to a 4 stroke before)
    I tried a search but couldnt quite find exactly what i was looking for. Can someone explain (or show me a link to a website) how to set timing on a 185s. Its needs to be step by step from the beginning. Im assuming I need to set everything...valves, spark, etc.
    Thanks
    My current stable:
    1981 Honda ATC110 (sold)
    1986 KTM 80 MX (for sale)
    85+86' KTM 500MXs (sold)
    1973 Yamaha AT3 125
    1971 Suzuki MT50 Trailhopper
    2005 Kawasaki Ninja 250 (for sale)
    2000 Ducati SuperSport 900ie (for sale)
    Jul 2006
    western ny
    3,366
    naw man u hit it rite on the head. tdc then valves closed and thats it. then put the generator on then set the gap and your ready to roll.
    GIT IT RAAAGGGGG !!!!
    Feb 2007
    Massachusetts
    418
    hmm. Ok then. Anyone else have a different opinion. i just thought it was going to be much harder than this.
    What tools do i need?
    My current stable:
    1973 Yamaha AT3 125
    Nov 2006
    Tulare, California
    719
    A rough out-line. Get a manual. Ask on the boards, he should be able to help you out.
    Current Bike:
    1985 Honda 350X
    Bikes owned:
    1984 Honda 200X
    1982 Honda 250R
    1985 Honda 350X x3
    1985 Honda 250R x2
    1985 Honda 500X
    Feb 2007
    Massachusetts
    418
    damn, I dont want to spend $ on a manual yet because I dont know if i want to pick the trike up yet. i want to know how difficult of a job it is first.
    My current stable:
    1973 Yamaha AT3 125
    Jul 2006
    western ny
    3,366
    its not hard man. ive done it a million times on mine. ive done it so many dam times i almost have all the specs stuck in my head. its a very simple motor once you get into it.
    Feb 2006
    Central Florida
    1,090
    make sure you are at TDC on the compression stroke. also, make sure your cam sprocket marker is lined up with the notch in the head and your lobes should be facing down. pretty easy job.
    get a manual and get the trike!
    quiet people seem intelligent
    Feb 2007
    Massachusetts
    418
    Does it really matter if its on the compresion stroke or not? I figured tdc was tdc...and thats all there was to it. Damn, I guess i need a manual.
    My current stable:
    1973 Yamaha AT3 125
    stoney420's Avatar
    stoney420 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Bridgeport, NY
    363
    you can download a manual at http://www.3wheelerworldforums.com/s...ghlight=manual either for free or 1$ im not sure if he changed it yet, i didnt see the 185 but it may be in there..or you could download the closest one to it and im sure its not much different if any, will atleast give u a general idea for now..
    Mar 2007
    lakeville ma
    605
    that easy, maby ill fix it and beat on it more, nahhhhhhhhhh to lazy still have it if intrested
    NO 3 WHEELERS CURRENTLY SOLD THEM ALL
    02 GSXR 240 kit STRECHED
    03 BANSHEE 421 CUB
    07 LTR 450
    08 RZR
    05 f7
    07 KLX 110
    670 ho skidoo powered banshee
    1985 nacs kx 80 race quad
    Jul 2006
    western ny
    3,366
    Quote Originally Posted by VenomRS4 View Post
    yes it matters. if its not tdc on the compression stroke it wont spark when it should. it will spark while the piston is at the bottom (bdc). but as long as you use the marking on the fly wheel you should be ok. contact dammit for a manual. his are cheaper than ebay as far as i know.
    Tionesta, PA
    5,747
    Wait a minute - if that cam chain just "fell off" while the engine was running, you may have more internal engine damage than just putting the cam chain back on it and resetting the timing. You could have a bent valve at the very least.
    Just a heads up to you on this - sometimes these really "simple" jobs can be a real headache and money pit as well.
    Mar 2007
    lakeville ma
    605
    no my buddy pulled it out because hes a retard
    03 BANSHEE 421 CUB
    07 LTR 450
    08 RZR
    05 f7
    07 KLX 110
