Results 1 to 2 of 2
Thread: 85 200x kickstarter leaking oil? new pics!
    southern cal
    35
    Hey guys, just picked up an 85 200x and the only thing that seems to be wrong is it leaks a little bit of oil from the kickstarter. Any idea what the problem is? Old seal? trike is completely original from 85 so im guessing maybe some worn parts. Thanks for the input. Heres a link to the thread with the pictures on it, thanks to stoney http://www.3wheelerworldforums.com/s...ad.php?t=73807
    Solid Snake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    Lancaster, PA
    316
    Hard to say without a picture of that particular area. There is an oil seal there and that could be leaking, but there is also a gasket for the little cover that houses the 2 reversing gears for the kickstarter, that gasket is prone to leaking on a 200x. If it's that gasket that is leaking, some gasket sealer in conjunction with the gasket there will do just fine, you'll need to drain the oil first and clean it up real good though before applying some.
    Trikes
    1984 Honda 200x, 1984 Honda 200m
    Bikes
    1995 Honda CR125R, 1985 Honda XL100 (gone), 1982 Kawisaki KZ550 LTD,
    2001 Yamaha TT-R 125L, 1983 Honda XL185S (current project), 2001 Suzuki SV650S
