Thread: Operating Temperature
    Nightbiker07's Avatar
    Nightbiker07 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2007
    Toledo, Ohio
    382
    I was wondering. what would be an Ideal operating temperature for my 84 R?
    where would be the start of overheating? i want it to be jetted correctly, and i dont want it too lean and burn it up.
    i have a really good thermometer to check the temp, so that isnt an issue.
    ______________
    Current Rides:
    84 250R
    1980 XL80S
    little 6.5 HP minibike (Wicked Quick)
    2002 Ford Ranger, pulled out of a junkyard, fully radio-ified
    1969 Broncco TX-6 (yes its spelled correctly)
    92% of teens have switched to rap music if you are part of the other 8% put this in your sig.
    I want to come to Trikefest 08!
    Sep 2007
    Toledo, Ohio
    382
    does anyone know the ideal operating temperature and the temperature considered overheating?
    ______________
    Current Rides:
    84 250R
    1980 XL80S
    Sep 2007
    Toledo, Ohio
    382
    nobody as the slightest clue ay?
    ______________
    Current Rides:
    84 250R
    1980 XL80S
    CUYAHOGA FALLS, OHIO
    1,242
    No spec
    But your plug check will let you know a very close estimate. If the plug is whitish or a very light tan its running lean=hot. This is air cooled. You cant just let these things idle at a stop like a four stroke. Keep the mud cleaned out of the fins.
    When jetting do some plug chops. Your plug should look tan to brown.
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
    2011 KAW SXR800- 35YR EDITION
    05 HERITAGE/SPRINGER/SOFTTAIL
    Sep 2007
    Toledo, Ohio
    382
    cool thanx
    ______________
    Current Rides:
    84 250R
    1980 XL80S
    Feb 2006
    Central Florida
    1,090
    im guessing 290 is getting a little hot, what are you mic'n? I mic the plug since it should be the hottest part - I will check mine next time I ride it and let you know what it reads.. it is fat so should be cool.
    quiet people seem intelligent
