ok i got my swingarm today,,,, i got a lsr carrier and the little adjuster plates,,,i am not sure i understand how to use the center bolt holes.... are there special bolts for these?
You use a stock bolt but you have to finese it when installing it. Put the bolt in the adjustable insert first then put both bolt and insert in swingarm while also installing dogbone. Do all this without scratching or chipping new paint/powder![]()
ok i kinda figured it out after looking at it,,,, i am going to build a wide lowrider dune bike for my daughter,,, they never use all the suspension travel, i figured make it 4 inches lower and 6 inches wider she will really love it on the steep sidehills at glamis,,, and since she only weighs 120 lbs it should be kool......... do you have different colored decals for that swinger,? like white? and a set of bushings?
I can do them in any color but I would need to know what color your going with on the swinger for the rear decal so I can match the background. I've got material coming for more bushings so should have a few sets when your ready.
