Results 1 to 11 of 11
Thread: Dual muffler configuration on R ?
    Jan 2005
    Slatington PA
    4,372
    What effect on a R (air cooled model) would dual exhaust mufflers (both being the same brand), with the other one being "Y"ed to the other side have on it?
    Would you gain more top end, no better perfomance at all in any range, the same performance, worse or what ?
    I imagine with two, you have a lot less back pressure and it may be a bit uneven flow with more going to the original one ?
    Las Vegas, NV.
    2,491
    I think it would trick the bike into thinking it's an aircooled Banshee.
    Tilton Newfoundland
    612
    Buahhahahah thats wikked.. I honestly think all it would do is add weight. Look really cool though.
    1998 F150 reg cab
    Elan Ski-doo resto mod
    2012 Brute force 650
    98 ranger street truck project
    All my rigs are Loud and proud
    http://bikepics.com/members/mitchell-gosse/
    Jan 2005
    Slatington PA
    4,372
    Good! ......then it will be faster then
    florida
    2,328
    u mean think its an RD350 hehehe
    Nightbiker07's Avatar
    Nightbiker07 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2007
    Toledo, Ohio
    382
    i dont think that 2 silencers will offer any performance increase. in fact, looking at how a tuned pipe works, i think that a dual muffler configuration (unless manufactured like that) will hinder performance.
    http://en.wikipedia.org/wiki/2_stroke
    this link will help you to better understand what i mean.
    it would look cool as sin though
    ______________
    Current Rides:
    84 250R
    1980 XL80S
    little 6.5 HP minibike (Wicked Quick)
    2002 Ford Ranger, pulled out of a junkyard, fully radio-ified
    1969 Broncco TX-6 (yes its spelled correctly)
    92% of teens have switched to rap music if you are part of the other 8% put this in your sig.
    I want to come to Trikefest 08!
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by Nightbiker07 View Post
    Good link, thanks.
    Well I'm just interested in the looks part and if it stays at least equal then I'd do it. Actually I'm curious how it would sound too ? Probably much the same in tone with being a few decibals lower ?
    Sep 2007
    Toledo, Ohio
    382
    i know a guy with duals on his quad. not sure if it is like that from the manufacturer, or if its modified, but its loud as *Edited**Edited**Edited**Edited*. so probably no effect on the sound.
    ______________
    Current Rides:
    84 250R
    1980 XL80S
    Sep 2007
    California, USA about 50 miles north of sacremento
    976
    Warning.. I am not a engine repair mech.
    We have a term in computers repair called "bottle neck". This is where something restricts the flow of data. See little harsh mspaint drawing of why I think the dual exhaust would have no effect.
    If your exhuast port hole is 2 inches in diameter and you have stock single exhuast 2inch pipe you get the same amount of flow.
    If your exhuast port hole is 2 inches in daimeter and you have stock single 2 inch pipe that splits down the way to the "Y" pipe you should have the same amount of flow coming from the 2 inch exhuast port but the exhuast would flow through 2 pipes maybe giving it a bigger sound.
    If you increase the size of the pipe all the way back to the exhust port to a bigger size it may breath easier and maybe a performance gain.
    If you increase the exhuast port hole size and increase the pipe size you would maybe get a performace gain.
    Any thoughts?
    Sep 2007
    Toledo, Ohio
    382
    no, on an exhaust, expanding the pipe will give you a performance gain, almost guranteed. it drops the backpressure. only true on 4 strokes though.
    on a 2 stroke, yes, a bigger pipe will be better, but it has to be a tuned pipe...if its just a 2.5 inch pipe all the way out, its going to run like CRAP.
    ______________
    Current Rides:
    84 250R
    1980 XL80S
    Sep 2005
    Lipetsk, Russia
    2,824
    There was a stock dirt bike I remember seeing with dual tuned pipes on a single cylinder motor. I forgot what it was though. It was mighty old.
    I'm back in the USSR...
