Any Thing i Should look out for? Common Problems? Thanks,Derek
1985 Honda 200x
- 30mm Carb
- DG Exhaust
- Rear Wheel Spacers
- K & N Filter
Common problems? Stripped shifter shaft is the only one I know of, easy fix though, you just have to ground off one of the welds on the shifter as long as there are still teeth on the shaft and shifter. Other then that it's just normal maintenance things to look for.
Oh, the shifter and shaft is not that hard of a fix if it does go bad (I went through a shaft and 2 shifters on mine before I found the weld that needed to be ground down). The KLT110 was my first trike, fun machines!
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
Just got one myself!! I love it!! My Hondas are getting jealous me thinks. Only thing that sux is that there isn't a HORDE of parts available on ebay like I've gotten used to with my other trikes. Just ordered a float, float needle and cables from Kawi though so parts seem to still be available new. Also, I drained the forks and replaced the fork oil, (hondaline 10wgt). Much better ride. Get us some pics!!!
yup good bikes! and MOST of the KLT parts are still available INCLUDING fueltanks.
