Page 12 of 16 FirstFirst ... 2 10 11 12 13 14 ... LastLast
Results 166 to 180 of 226
Thread: Aluminum 450r 3 wheeler.
  1. #166
    bullville ny
    26
    good job on a difficult build
    A++++ ON THE FAB JOB BUD
    if we ever cross paths i wanna ride it! (beers on me of course!)
  2. #167
    Jackson MI
    1,688
    Thank you very much, when we cross paths you are welcome to a ride!!!
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
  3. #168
    Feb 2009
    greece
    102
    jason i started the project i tolled you about....here is the link.
  4. #169
    audioworks04's Avatar
    Oct 2008
    Kansas City, KS
    332
    jason; are you using the stock crf450r kicker or something different? also are you using the trx carb or the crf and if the crf how did you convert it to a thumb instead of twist? is there a conversion kit out there somewhere?
    86 atc250r stock sand only
    88 NX250 mint rainy day
  5. #170
    Oct 2007
    Grosse Tete, LA
    3,440
    I can answer the carb question....
    when using the push pull FCR carb...it's very simple to just seal off one of the holes and then just connect the other cable to a 450r throttle.
    doing the same thing with the 37mm FCR...
    I don't know if that's what he did, but it does work.
  6. #171
    Oct 2008
    Kansas City, KS
    332
    i have heard of doing it that way, but have also heard that the return spring on the fcr isnt strong enough to work just solely as a pull set up. not sure this is right just what I have heard from others.
  7. #172
    Jackson MI
    1,688
    I used a cr125 kicker & nuckle with a custom adaptor. The goat Is right, I just bought a YFZ450 throttle cable and hooked It to the pull side of the carb. I then plugged the other hole with silicone. I have no problems with the throttle returning. I use the CRF carb on my bike.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
  8. #173
    Mar 2004
    North Central Ohio!!
    2,712
    Goat... MotoWoz shocks are the chit! Very well built shocks from what I hear.
  9. #174
    Mar 2004
    2,712
    Will do, Goat. Heading there next weekend. Heard you have a hell of a 350X coming!
  10. #175
    Oct 2008
    Kansas City, KS
    332
    jason: what did you use for the swing arm pivot bolt I that the trx uses a smaller size diameter bolt than the crf. Did you end up boring the trx swinger and using the crf bolt and bearings or make a space for the trx bolt as it passes through the motor?
  11. #176
    Jackson MI
    1,688
    I made stainless steel reducer bushings that press Into the frame, and used a shortened TRX bolt.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
  12. #177
    Oct 2008
    Kansas City, KS
    332
    Do you still have the dimensions of this bushing you made? If so is there anyway that you could make me one and ship it too me. This is one of the last few things I have left to fidgure out. The others being rear brake pedal and the airbox. Send me a price and let me know if its possible.
  13. #178
    Oct 2008
    Kansas City, KS
    332
    any idea what temp your head pipe gets up to? Mine hits 350 after just a few minute idle. Thinking i might still be a little lean, but it runs great so not sure if i want to change something.
  14. #179
    Mar 2009
    Wake Forest, NC
    80
    Quote Originally Posted by audioworks04 View Post
    Its not good to let it idle too long, the mx engine runs hot! When I'm on the starting gate mine would dump coolant if I let it idle too long. It would be good to install a Boyesen water pump for better cooling.
  15. #180
    Mar 2009
    Wake Forest, NC
    80
    Jason AWSOME work dude. You have inspired me to do a project like yours. You have tons of time and money into this project. Great job. I have sent links to all my friends about your build.
