Results 1 to 15 of 18
Thread: 83/84 R axle bearings and seals .
    Jan 2005
    Slatington PA
    4,372
    Are they ever on ebay, a kit ? I didn't see any when I checked.
    If not, do you have a link to a company that has a kit ?
    Pa.'s Highest City
    8,058
    Hey Gary.. All balls has them.. PM dads here on the forums. He's a dealer and has great prices and service.
    http://www.3wheeler.org/vb/showthread.php?t=19500
    I suppose you can go the oem way as well...
    Jan 2005
    Slatington PA
    4,372
    Good morning and thanks man!
    I found them here too now.......... (would rather buy from a member though if price is fair)
    http://cgi.ebay.ca/REAR-AXLE-BEARING...QQcmdZViewItem
    Start her up in a few hours ?
    Pa.'s Highest City
    8,058
    not good.. great morning.
    I'd respond to this statement here but dont want to be considerd a POSTWHORE!!
    Jan 2005
    Slatington PA
    4,372
    That's cool and HAVE FUN!!!
    Take a small screw driver with you, carry it with you that is, for air screw and idle adjustment. Turn the air a 1/4 at a time and find out (you might know) what the stock setting is from being closed.
    Usually the air screw is around 1&1/2 to two out from closed .
    Pa.'s Highest City
    8,058
    gotcha!
    Sorry bud.. but that thread in the open forum has me fired up a bit.
    I've gotten all my bearings from dads.. 200x, 250sx,, tri z,, and lt230. There was a mixup once with the z front axle bearings...but he even refunded my shipping charges. one heck of a nice guy!
    Jan 2005
    Slatington PA
    4,372
    Fired up as in pissed off ? or am I miss understanding that, maybe you mean excited ?
    Jul 2006
    the bearings in a 83-85 are the same as the 85-86 to make things easy
    Jun 2006
    Ohio
    2,294
    No, the 81-84 250r are the same, but the 85-86 are a different bearing and seal.
    They are also a lot cheaper than the 85-86.
    The Front wheel bearing however, are the same on 81-86 250R.
    1981 ATC 70
    1978 ATC 90
    1985 ATC 250R
    www.cosmicquads.com
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by Mrs.moshman View Post
    Thanks for the correction. Do you sell them Mrs. Moshman ?
    Do you sell them Mrs. Moshman, just noticed the " Now offering OEM and after market parts."
    Jun 2006
    Ohio
    2,294
    Yes, I do but I don't want to step on Dads. I sell a lot of parts, I just don't advertise them much, because I know Dads is known for bearings. I'm not out to ruin anybody elses ventures. If you can't get ahold of Dads, get a hold of me and I will help you out.
    1981 ATC 70
    1978 ATC 90
    1985 ATC 250R
    www.cosmicquads.com
    Jul 2006
    well then how come I bought 2 sets with the same part numbers and put 1 set in my 85 and 1 set in my 83? both looked the same and were the same size and the bearings had the same numbers.
    Jan 2005
    Slatington PA
    4,372
    Check here, see if they are the same, full parts schematics on all ATC's, very easy to use.
    http://www.ridemsc.com/default.asp
    Jul 2006
    well I have both shop manuals for the air cooled and liquid, I just bought bearings for both they were listed for each bike but when I got them they were 2 of the same set so I was like wtf? did I get the wrong set and since I had both apart I stuck them in each carrier and walla both fit like stock everything went back together and is tighter than.... (ok I'll not be obscene) welll.... you get the picture!
    Jun 2006
    Ohio
    2,294
    I don't know what you did? The bearings are the "same size" outside, but the inner diameter is completely different. Heres a pic......
    Not to mention, the 85-86 is thicker than the 81-84 bearing.
    1981 ATC 70
    1978 ATC 90
    1985 ATC 250R
    www.cosmicquads.com
