Results 1 to 7 of 7
Thread: chain links?
    Aug 2006
    NW Ohio
    1,043
    chain links?
    Ok I need a rough guesstament. I have a 1986 310r with a +9" extended swingarm a 44 tooth rear sprocket and a 15 tooth front sprocket. Will 120 links be enough or will I need more? Approxemently how many will I need? If someone will count there links on there +8 to +12 and get me a count I can add or subtract from there. I need to know within the next 2hours if someone could help me out.
    Thanks
    Alex
    ATC500AF
    Aug 2004
    Ab Canada
    4,368
    Use a piece of string
    1985 Tri-Z-
    Jul 2006
    iowa
    451
    whats the stock gearing and chain on a 250r? if the stock chain would fit about right with your gearing, figure out how many links are in 18", and then add that to the stock chain plus a few to make sure you goto enough.
    Aug 2006
    NW Ohio
    1,043
    stock gearing is 13 39 but i have no clue on the stock chain MAYBE... 96?
    ATC500AF
    Aug 2006
    NW Ohio
    1,043
    ok so i measured and need 7ft of chain does 84 links sound right?
    ATC500AF
    Jan 2005
    RI
    2,530
    sotck 250r is like 94 links....
    i dont think its 7 ft long...
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Aug 2006
    NW Ohio
    1,043
    ive got a +9 swinger and i was thinking each link was one inch i knew it didnt sound right. but thanks figured it out i need 140 links thanks for the time
    ATC500AF
