bone stock,original piston Temp today 58 .
main jet 140
pilot jet stock
needle clip positon : all the way to the top
air screw 3/4 turn out from full in
32 to 1 mix.
I know you guys will say this is way too lean but the bike is flat out arm ripping
10 degree change in temp is noticeable. I can usually get that in the air screw
bike is crazy fast,no death rattle, no lean bog just sick bottom end alll the way to the rev limiter
Best setup I have found for woods and tight tracks where you are only wide open for 2-4 seconds up to 4th gear.
