Excellent choice on the axle! They are best ones made out there.
4 Strokes are NOT the wave of the future!
I wish I never opened this thread! Im sooooo envious/confused now. I wouldnt even know where to begin in a million years![]()
Ill probably cry when I see the finished product knowing that ill never have a chance making something THAT NICE. Seriously mad props on making that thing. Cant wait to see what it will look like in the end
1986 200x- old school D.I.D wheels, Gold D.I.D X-Ring Chain, Rad MFG. Carrier, PRM Grab Bar, Pro Circuit T-4 custom, Maier plastics, 85x forks, 18x10.5x8 kenda klaw mxr's on itp steels, the money pit never ends![]()
1986 ATC 70
1985 ATC 250R - Hondaline Special
1985 ATC 250R - Flat Track 'Privateer'
1985 ATC 250R - HRC 450RR.
1986 ATC 250R - HRC Flat Track.
1998 Honda Laegers TRX 250R (CT 350 PV) N/F cr500 link.
1998 Honda Laegers TRX 250R (Sparks 330) N/F cr500 link.
1999 Honda Laegers TRX 250R (Sparks 330) N/F cr500 link.
2016 Yamaha Laeger's Banshee YFZ 350 (DRI 350) N/F cr500 link.
HONDA HRC 450RR
Okay guy's here's some more pics for ya, ROSSIER Engineering Exhaust
1986 ATC 70
1986 ATC 70
I would cut that tab off the exhaust in front of the muffler if its not going to bolt up to anything.
Thanks for all the pics, I/we appreciate it.
3-85 ATC 70
86 ATC 250R
86 WETBIKE
01 KX250
2011 KAW SXR800- 35YR EDITION
05 HERITAGE/SPRINGER/SOFTTAIL
no,no,no,no,no....that just won't do....you should sell that one to me and start over.....sh#t man! That is amazing work you've done there. I envy your skill and workmanship. I can't wait for more updates.
Hi Max,
The pic shown is actually a few days old, the tab, as you suggested has been removed and replaced with another longer mounting tab, the reason the tab has'nt been modified before the pic was taken was the welding issue. I am very fortunate to have a complete steel/fabrication workshop at my disposal, unfortunately it's a 1 hr drive from my garage, so as the pipe is stainless steel and needs TIG welded i took the pic before i could get up there.
The Rossier exhaust is a 3 piece system, and the HRC is 2 piece, so as you'll appreciate, it's not quite as simple as plug 'n 'play, i have had to modify the middle section of the rossier exhaust, and the pic was taken before i modified the tab, as you will see in the final build pics the tab will be there as designed.
Glad you like the build,
G.
1986 ATC 70
is there enough room to pull the valve cover to adjust the valves? or do you have to pull the motor?
Bryan,
To answer your question truthfully i have no idea, the engine only has 20 hrs use on it and the valves have been checked prior to instal.
i honestly have'nt tried removing the cover while in the frame to check, i've been to excited building the thing!![]()
But thats something to be checked further down the road,
I've got this far, setting up a few valves, further down the road, will be a walk in the park - i HOPE![]()
1986 ATC 70
If Carlsberg made trike's ??
198? Manco Quester 300
1983 KLT 200
1984 Tri-Zinger 60
1985 ATC 70
1985 TRI-Z
1985 TRI-Z (two Wheel)
1985 ATC 250R
1985.5 TRI-Z
1986 TRI-Z (quad)
1986 Tecate
1987 Malaguti Ranocchio 50
2001 YZ 250
whats the other pipe sitting on the box?and your fishing poles are collecting dust
, the other pipes the 450 oem with modified HRC tip
, but i've decided to shelf that for the Rossie,,,,
, ye the fly fishing has had to take a back seat until i finish my 4FIDDY,,,, plenty of time for a tight line latter Dude!!!
Funny how you look around peoples garages in the pics they send, i do the same thing
1986 ATC 70
1986 ATC 70
