Page 5 of 28 FirstFirst ... 3 4 5 6 7 15 ... LastLast
Results 61 to 75 of 406
Thread: Honda HRC 450RR
  1. #61
    Oct 2007
    Grosse Tete, LA
    3,440
    yep, and one of the funniest and most intelligent comics you can ever hope to find.
  2. #62
    250rfan's Avatar
    250rfan is offline Sickest custom 450R ever. Arm chair racerJust too addicted
    SCOTLAND - UK
    479
    Hrc 450rr
    Right, getting near the end of the frame modification now, the next step is the change from 85 250r rear brake system to the 2006/7 trx 450r brake system.
    The first pic shows the TRX 450r mounting bracket for the rear brake master cylinder, the bracket also incorporates the exhaust mounting hanger, i made a copy of the mounting plate/bracket using card, then transfered it onto 6mm steel plate.
    As you can see in the following pics, the new mounting plate was tacked into position, i had to make a small tee shaped bush to insert inside the OEM brake peddle mount, this was drilled and tapped this allowed me to use the OEM 450 rear brake peddle.
    Then i made a small bracket just above the peddle to fasten the return spring.
    You can also see in the pics, the coolant reservior bottle has been mounted, and also the rear brake reservoir, i have removed the original master cylinder mount from the frame, as it is no longer required, i will extend the plate which is left to give strength to the rear subframe, and basicaly make it look right.
    If you're wondering what the black plastic piece connected to the peddle is, it's a micro switch for operating the rear brake light.
    NEXT STEP - THE BATTERY!
    Attached Thumbnails Attached Thumbnails 450R FRAME MODIFICATION 024.jpg   450R 042.jpg   450R 043.jpg   450R 044.jpg   450R 045.jpg   IMG00102.jpg
    1986 ATC 70
    1985 ATC 250R - Hondaline Special
    1985 ATC 250R - Flat Track 'Privateer'
    1985 ATC 250R - HRC 450RR.
    1986 ATC 250R - HRC Flat Track.
    1998 Honda Laegers TRX 250R (CT 350 PV) N/F cr500 link.
    1998 Honda Laegers TRX 250R (Sparks 330) N/F cr500 link.
    1999 Honda Laegers TRX 250R (Sparks 330) N/F cr500 link.
    2016 Yamaha Laeger's Banshee YFZ 350 (DRI 350) N/F cr500 link.
  3. #63
    250rfan's Avatar
    SCOTLAND - UK
    479
    Hrc 450rr
    Well here's the progress on the battery, i could have bolted it onto the side where the tool box would normally be, but i want to use the 86 OEM toolbox, so i have mounted the battery inside the air box.
    This keeps it more or less hidden, it sits inside perfectly, the solinoid is also mounted inside along with some of the wiring harness, this keeps everything nice and neat.
    So that's basically the the bike finished as far as mock up is concerned, next step is to dis-assemble, finish final welding of the frame, Powder coating, and then the BEST part - FINAL BUILD,,,,,
    Attached Thumbnails Attached Thumbnails 450R FRAME MODIFICATION 034.jpg   450R FRAME MODIFICATION 038.jpg   450R 058.jpg
    1986 ATC 70
  4. #64
    Apr 2004
    Brigham, Québec, Canada
    1,528
    How many time do you invest in this project????
    This bike should look awesome when done.
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
  5. #65
    250rfan's Avatar
    SCOTLAND - UK
    479
    Hrc 450rr
    Quote Originally Posted by Yamada View Post
    Not sure really - a few months or so, the plan has been in my head for some time, but i had to wait until i finished my first 2 projects, which you can see pics of on this thread by edog - post pics of your 85,86 Hondaline optional extras in trikesalvania.
    I've allways wanted a 4 stroke trike, the 350x really, but i decided to take it a step further and build a bike with everything i want on a trike,,,, your right the bike will look awesome when done - its nearly finished. im going to start posting the final build pics soon.
    Thanks
    1986 ATC 70
  6. #66
    Sep 2005
    Lipetsk, Russia
    2,824
    Quote Originally Posted by The Goat View Post
    I would slay an infant for derrick's yamaha
    Oh yeah, you're not the first or the last one to say that ....
    I'm back in the USSR...
  7. #67
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    !!!!!!!!!!Great thread!!!!!!!!!!
  8. #68
    250rfan's Avatar
    SCOTLAND - UK
    479
    Hrc 450rr
    Here's some pics of the frame after final TIG welding.
    1986 ATC 70
  9. #69
    250rfan's Avatar
    SCOTLAND - UK
    479
    Hrc 450rr
    Here's the last of them -
    Now to the powder coaters!
    1986 ATC 70
  10. #70
    Mar 2007
    lakeville ma
    605
    awsome weld's can't wait to see the end product
    NO 3 WHEELERS CURRENTLY SOLD THEM ALL
    02 GSXR 240 kit STRECHED
    03 BANSHEE 421 CUB
    07 LTR 450
    08 RZR
    05 f7
    07 KLX 110
    670 ho skidoo powered banshee
    1985 nacs kx 80 race quad
  11. #71
    Dec 2006
    Las Vegas, NV
    421
    wow! what a great thread! .... but I have to say.... that if this beast doesnt get inverted forks .... I AM GONNA BE PISSED!
    85 350X, 85 250R, 99 TRX 90, 05 Predator 90, 05 TRX 400ex, 2019 RZR4 XP100
    FEEDBACK for Vegas250rr
  12. #72
    250rfan's Avatar
    SCOTLAND - UK
    479
    Hrc 450rr
    Quote Originally Posted by vegas250rr View Post
    Dont worry man, your not going to be pissed! , Here's the USD forks for the beast ( http://marzocchi.com/template/listSP...=UK&Sito=moto), check out the SHIVER USD 045 FACTORY WORKS, they're bought and altered,,,,, just waiting on the Billet triples to get made,,,,,,,thats the only thing holding the build from finish
    1986 ATC 70
  13. #73
    Apr 2004
    1,528
    Do you take it for a ride??? By the pics it seems complete before you dismanteled it.
  14. #74
    250rfan's Avatar
    SCOTLAND - UK
    479
    Hrc 450rr
    Ye, i have taken it for a ride, unfortunately not as fast as i would have liked,,,, due to the fitting of the stock 450r rear shock , i was unable to connect the air box to the carb ( the shock reservoir was in the way), so the engine was running real lean, and basically would'nt run right, i tried restricting the air intake with a rag but the carb just sucked a hole in it.
    The main point for test riding was to make sure everything fitted and worked together, which it did, the New rear shock has a remote reservoir attached to it so this leaves clear passage to hook up the air box to the carb,
    1986 ATC 70
  15. #75
    250rfan's Avatar
    SCOTLAND - UK
    479
    Honda HRC 450RR
    HONDA HRC 450RR
    Okay guys here goes the final build pics.
    These pictures show the frame after Powder coating
    Powder coating was silver with clear gloss, , what do you think so far?
    1986 ATC 70
