Results 1 to 13 of 13
Thread: 250r motor in a 200X
    big schott's Avatar
    big schott is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2007
    Western Minnesota
    244
    Does anyone know if a 83-85 250R motor will fit in a 85 200X? I would like try but don't have a 250R motor to check if it will fit. I would rather try a air cooled than the liquid.
    What do you think?
    1978 Honda 90 / 1979 Honda 110 / 1983 Honda 110 Racer (in the Works)
    1973 Honda 70 / 1983 Honda 70 / 1983 Honda X-mas special / 1984 Honda 70 / 1985 Honda 70
    1985 Honda 200X Stock Original
    1985 Honda 350X
    1985 Honda 250R
    1986 Honda 350X
    1987 Honda 250SX
    Nov 2002
    Kirkville, NY
    3,831
    Well for starters the chain is on the worng side. I'm sure you could do it with some time, I think there are pictures of one with this swap. Not a "bolt in" type swap for sure though.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Uggh........ I give you guys credit for thinking and attempting these conversions. But rarely do they come out good and handle well. Honda made frames and suspension for each model for a reason. Some conversions are very very well done and worth the trouble but 75% of them are a waste of your imagination. These swaps are never easy.....
    The 86/87 200X has a nice suspension and handling setup and a larger frame cradle. I believe it could benefit with a 2 stroke motor. But I don't think the 85 and under 200X will benefit, although you will find them with 400cc street bike motors in them
    big schott's Avatar
    Feb 2007
    Western Minnesota
    244
    Your right. DAMMIT! OK, Well, is their a 2cycle 200-250 Honda motor made that would work in a 200X.
    1985 Honda 350X
    1985 Honda 250R
    1986 Honda 350X
    1987 Honda 250SX
    Sep 2007
    British Columbia, Canada
    818
    My 175cc engine is a damn tight fit in the X frame, so I don't see a 200-250 2 stroke fitting in there without some major modification.
    Are you looking for something that will bolt in with minor mods, or are you willing to go all out and do whatever it takes?
    [b]'83 200X-
    White/Blue:
    The 2 stroke 200X
    Vids:http://youtube.com/watch?v=HwDqUVM9jOo
    big schott's Avatar
    Feb 2007
    Western Minnesota
    244
    I would like a bolt in mod but, I can build/rebuild what needs to make it work.
    What I am trying to do is take the X that is in the pict. and make it into a Ice racer this winter. I need to make it screem and the 2 stroke seems to be the best wa to make it do this.
    I have lowered it and with the wider tires and rims I can run this thing wide open in the corners (on dry gravel). I know that it is not fast enough to play with the big boys but if I could make it faster and make the rear wheels spin (the way 2 strokes can) I know this light, low, WIDE ride will be one for the contending!
    1985 Honda 350X
    1985 Honda 250R
    1986 Honda 350X
    1987 Honda 250SX
    Ohio
    593
    well try a cr125 motor? or similar.
    Williamstown PA
    5,826
    kx100 motor, or rm100, you'd need radiators but it would have some snap and be smaller then a 125 motor.
    Jul 2006
    why not a blaster motor? there light, super cheap to build and everywhere!
    Phoenix, AZ.
    6,719
    Not trying to be a smartass but, why not just look for an air cooled 250R? By the time it's all said and done it would probably be cheaper and still be a better machine.
    Masshole
    2,191
    And they are air cooled, that much less fabricating.
    Jul 2006
    honestly I alway nocked around the idea of a tri-z with a blaster motor in it, I think that would be trick!
    That is an excellent suggestion... Such a simple motor, easy to unleash it's power potential and tons of them out there.
