I got my 1982 yamaha tri-moto running and its a 175cc 2 stroke and it smokes blue smoke out the tail pipe is that normal?
Yes.Its a 2 stroke.
1986 200x- old school D.I.D wheels, Gold D.I.D X-Ring Chain, Rad MFG. Carrier, PRM Grab Bar, Pro Circuit T-4 custom, Maier plastics, 85x forks, 18x10.5x8 kenda klaw mxr's on itp steels, the money pit never ends![]()
Two-strokes always smoke. If I were you, I'd ditch the oil injection, learn to premix and just mix your own gas. Cuts down on the chance that your oil pump would go bad and cost you a new top end or more damage.
I'm back in the USSR...
GET A MANUAL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
You'll thank me later![]()
OK Like I posted WHERE IS A MANUAL?
you post for every thing....
ok, after you get your oil injection disconnected make sure you cover up the oil holes on the outside of the carb, pre mix, use any high quality 2 stoke oil (that you cant buy at wall mart!) mix it 32 to 1 or 20 oz to 5 gallons of gas 20 oz is a coke bottle, we dont want to hear about you seizing your motor just DO IT!
Actually for 32:1 you'll need 25.5 oz per 5 gallons
so you went and got it eh? good job good luck with it
86-tecate
lol no wonder ppl's bikes break down
86-tecate
well, to make it REALLY simple......a 32:1 mix would be 1 GALLON of oil to 32 GALLONS of fuel...........so 1/2 gal. oil to 16 gal. fuel, 1/4 gal (quart) to 8 gal. fuel.........
______________
Current Rides:
84 250R
1980 XL80S
little 6.5 HP minibike (Wicked Quick)
2002 Ford Ranger, pulled out of a junkyard, fully radio-ified
1969 Broncco TX-6 (yes its spelled correctly)
92% of teens have switched to rap music if you are part of the other 8% put this in your sig.
I want to come to Trikefest 08!
A ratio-rite never lies, theyre like 4 bux
