there is some pretty big markings on my piston its a tri-z 1985 i would upload pics but they are to big i guess so should i get a new piston? or i shud be ok?
86-tecate
lol was thinking about upgrading but not yet and what should the cylinder look like cuz there is a fer markings on it as well
86-tecate
Reduce the picture size and post hard to tell with just words.
'WHEN IN DOUBT.........GAS IT!'
87 KXT250B2 Tecate
86 ATC250ES BIG RED
85 ATC350X
85 ATC70
'A FEW IN PARTS'
not very good with comps how do you redce pic size
86-tecate
You need a program that reduces picture sizes. May be easy to find one at Downloads.com or some other gys here probably know where to get an easy one...
ok thxs but i think i just myt bore it and get a new piston and port n polish reeds all that good stuff anyone got any suggestion?
86-tecate
send me the pics at stoney_mcbonghitter420@yahoo.com and ill post them for you
Just make an account on http://www.photobucket.com then you upload yours pics to *Edited**Edited* computer then login and upload them there and theres a dropdown bar to resize the pictures... I hope I helped
A piston is just a carrier for the rings, some little scratches in the skirts of the piston wont hurt anything, as long as the ring grooves arent worn id say run it.
yea its not scratched on skirts its way up by the top and rings
86-tecate
why did u take it apart? was it loosing compression? i would never put a piston back in unless it was tight in the cyl. and only if i couldnt catch the scratch with my fingernail same with the cyl. because it will just damage a new piston
TRIKES
1983 225 DX
1984 Tri-Zinger
1984 200 X
1985 Big Red
1985 200 X
1985 Tri-Z
1985.5 Tri-Z
1986 Tri-Z
BIKES
1978 YZ250
2010 YZ250F
2015 WR450F OHIO Street Legal
just do the top end , add the V-force 3 reeds , 36 - 38 mm Carb
K&N air filter with sock , and Exhaust if you don't have it already !
O forgot up-grade you water pump ...
got a blown gasket between the cylinder n base and upgrade water pump how?
86-tecate
