Results 1 to 2 of 2
Thread: sx forks
    Oct 2007
    albert county nb canada
    10
    sx forks
    i keep blowin fork seals so i gave up.what would be a good alternative fork for my sx,i weigh about 175lbs and drive the bag off my bike.im a steel fabricator so i can make custom triple trees,axle,hub whatever.cant find 200x forks that r good.i have xl 250 forks but they're rusted up bad.any suggestions.more travel would be better
    i love trikes cause they're cheap and im poor
    The SX is limited. 200X forks are the best companion to the rear pogo stick. 250R and 350X front ends are also a bolt on item.
    If your blowing fork seals - your bushing may be worn out, your putting air in them which is not advised or the upper leg is bent and or pitted.
    I have jumped an SX as big as anyone else and didn't have a fork seal blowing issue. Your 175 and I was as much as 225lbs and riding on an MX track with mine......
