Results 1 to 8 of 8
Thread: 250SX Brakes?
    Nov 2006
    Northern Michigan
    131
    250SX Brakes?
    What are the signs of needing new cables....?
    The brakes work well but there is no tention on the hand levers always feel kind of loose.
    The rear brakes never totaly release after you stop... If I pull back on the arm on the rear wheel they free up very easily. where the cable attaches by the foot pedal there is nothing holding the cable firmly. looks like there should be its just floating in a little clamp on the frame.
    Any help would be great... Its still very rideable I am loving the 250SX.
    thanks in advance.
    1984 200s SOLD1984 200ES BIG RED SOLD
    [1986 250SX SOLD
    NEED A NEW RIDE!
    Jul 2006
    I take it all apart and clean everything real good . Grease it up where needed and buy new cables. It will make a world of differents.
    Sep 2006
    S.E. LA
    700
    Did you try adjusting the cable?
    '85 Honda 250ES Big Red
    '97 Polaris Sportsman 400 4x4 2-stroke
    '04 EZGO TXT
    Former trikes;
    85 & 86 ATC 250es Big Reds, 200e, 185s, 200s, (2) '84 250r, Yamaha 175 2-stroke, ATC 70, (2) ATC 110, TriZinger 60
    ***GOD BLESS AMERICA AND OUR TROOPS***
    Oct 2007
    albert county nb canada
    10
    haha brakes are a luxury,i think i had em for about 2 weeks,downshift brotha
    i love trikes cause they're cheap and im poor
    If the cables are old, at the end of there adjustment, open somewhere or don't slide with ease then you need new ones. The SX cables can be a PITA to adjust. Even with new cables for some reason it's tough to get the same freeplay and feeling in both the foot lever and handle lever and or one of them always feels mushy. You have to screw around with all the adjusters and it's best first to yank that drum, clean the pads and grease both the pivot points and shaft that the brake arm connects to. If any of this stuff is worn, you'll never get it right without drag or too much freeplay in one or the other. Make sure that they are routed correctly also.
    I mostly ran just a foot lever cable but a 200X disc front end. Then you end up using the front disc more than anythin else.
    Nov 2006
    Northern Michigan
    131
    wheres the best place toi get the cables? (Want to avoid dealer high $)
    [1986 250SX SOLD
    NEED A NEW RIDE!
    Jan 2005
    Slatington PA
    4,372
    Don't go getting new cables if they only need lubing, do you know how to lube them ?
    Your back brakes just need a good cleaning and most likely the cam that spreads the shoes has a lot of dirt on where it goes thru the plate and needs to be slid out, cleaned and lubed.
    If you have a 85 they are terrible at sealing out dirt and water.
    That's one thing (cleaning brakes) on the 85 that needs constant attention if you go in mud/water a lot.
    This place here has cables for you, if you do order them, measure yours 1st, make sure they are the same length.
    http://www.hyperparts.com/wc.dll?ctw...00089~Honda~21
    Nov 2006
    Northern Michigan
    131
    will the cam just slide out?
    [1986 250SX SOLD
    NEED A NEW RIDE!
