Results 1 to 9 of 9
Thread: TRX 450 exhausting out the intake
    oldred95 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2006
    OK
    196
    My dad bought a well used TRX 450 (yea its not an ATC but its still a honda) and we got it running but it was blowing the exhaust out the carb. and it had a lot of crankcase pressure too. Took the exhaust off and it seemed to run a lot better so we figured the muffler must be plugged. Cut the muffler open and it was clean. Ok so we pull the rockers so the valves would be closed, pressured up the cylinder with air and no leakage out the intake or exhaust but there was a slight hiss of a leak somewhere. So we pull the head off and the head gasket (metal shim gasket) has been hot and warped and fubar'd in general and was leaking. Roll the engine over and notice the huge ridge at the top of the cylinder so we pull the sleeve and now its getting bore and a valve job done. Anyway what we still can't understand is why it was exhausting out the intake. We checked the timing chain and its tight but we did not check the cam timing. If the cam timing was off enough for it to exhaust out the intake I wouldn't think it would even run. Other then needing a little throttle to start it seemed to run ok other then no compression and exhaust out the intake. It makes no sense. This is the first 450 we've been into and I was just wondering if any of you guys knew what might cause this.
    1984 200X bored .040 over, mild port work, K&N filter
    Planning on custom exhaust, XR200 carb and cam
    Sep 2007
    Hawley MN
    144
    cam timing was off
    BOO, BOO, BOO, BOO - No quads allowed here!!
    Remove one tire and I'll bet it will fix itself.
    Dec 2006
    OK
    196
    Do you think timing chaing stretch could throw it off that much? The guy said it had a "carburetor problem" but otherwise ran fine. Once we started tearing into it we found a motor mount bolt almost all the way out and the owner said they had done some "work" to it. I doesn't appear have been torn down to the cam chain but we may have to. Guess we'll check the cam timing and go from there.
    Dec 2006
    OK
    196
    LOL
    Yea they aren't my favorite but still. My 125 3 wheeler was originally 4 wheeler and when I got it they had ridden it until the entire RF wheel assembly fell off and they kept on riding it after that. I rode it that way a few weeks before chopping it back down to a 3 wheeler frame and putting on a 200S frontend.
    Sep 2005
    Lipetsk, Russia
    2,824
    The timing is off. I think that yes, the timing chain could have stretched, but it's more likely that it got loose (stretch) and skipped time, changing the timing very seriously. I had a TRX125 that my friends rode so much/hard/didn't maintain, that it did the same thing.
    I'm back in the USSR...
    Dec 2006
    OK
    196
    We tore the engine on down a couple weeks back and the cam tensioner was bad and backed clear off and the chain had a boat load of slack in it and was just plain shot. On top of that the cam was advanced a good 20-30 camshaft degrees because it had jumped a few teeth on the chain. 122 bucks later a new chain and a 91 dollar tensioner fixed it. It runs like a demon now for a 450 and it actually sounds pretty good to with the reworked stock exhaust. I'm thinking about giving my 200x exhaust the same treatment rather then spend 200+ on an exhaust system.
    Sep 2005
    Lipetsk, Russia
    2,824
    Quote Originally Posted by oldred95 View Post
    So basically, exactly what I said. You're
    Dec 2006
    OK
    196
    Quote Originally Posted by RedRider_AK View Post
    Yea pretty much.
