Results 1 to 15 of 17
Thread: How do I get the swing arm bearings out
    VenomRS4 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2007
    Massachusetts
    418
    How do you get these ($^(*#^(^ bearings out? I cannot get them out for the life of me.
    My current stable:
    1981 Honda ATC110 (sold)
    1986 KTM 80 MX (for sale)
    85+86' KTM 500MXs (sold)
    1973 Yamaha AT3 125
    1971 Suzuki MT50 Trailhopper
    2005 Kawasaki Ninja 250 (for sale)
    2000 Ducati SuperSport 900ie (for sale)
    Nightbiker07's Avatar
    Nightbiker07 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2007
    Toledo, Ohio
    382
    get a REALLY big .....beat the shat outta it till they pop out........
    ______________
    Current Rides:
    84 250R
    1980 XL80S
    little 6.5 HP minibike (Wicked Quick)
    2002 Ford Ranger, pulled out of a junkyard, fully radio-ified
    1969 Broncco TX-6 (yes its spelled correctly)
    92% of teens have switched to rap music if you are part of the other 8% put this in your sig.
    I want to come to Trikefest 08!
    Masshole
    2,191
    Quote Originally Posted by Nightbiker07 View Post
    Dont do that, your asking for trouble. Heat the housing with a torch, they will fall out.
    Aug 2006
    new hampshire
    914
    even if you do beat the hell out of them nothing is going too happen. the outer cage for the bearing is very thing.
    1982 ATC 70
    1983 ATC 200E yard rat
    1984 ATC 200X
    1984 ATC 200S (X2)
    1985 ATC 70 (X2)
    1985 ATC 200S
    1985 ATC 250R
    1986 TRX 70
    1986 ATC 350X
    2004 kfx 700 XC
    2006 prarie 700 XC
    2009 Brute Force 750
    2020 CF Moto 600
    Feb 2007
    Massachusetts
    418
    It took a lo of finesse, but they came out. We used a blow torch and penetrating oil combined with a bit of banging and prying.
    My current stable:
    1973 Yamaha AT3 125
    Sep 2007
    Hawley MN
    144
    bearing puller, and heat!
    leroy,ny
    245
    keep pounding my friend!
    leroy,ny
    245
    Quote Originally Posted by jeffatc250r View Post
    I tried a torch... they didnt fall shat.
    Masshole
    2,191
    Quote Originally Posted by topoortorideon4 View Post
    Then your torch sucks I wasnt talking about a propane torch
    Anaheim
    1,270
    i had to press my stockers out... 2000 pounds lol, SWEAR U NOT
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    Fresno Ca
    2,695
    Use your heads you guys. Its hard to get a swinger in a press and get good pressure on the berring, Too much heat can realy make you end up taking back steps. Just get a die grinder or dremmel and cut it out, Takes a little more time but you wont screw anything up.
    breastman569 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2005
    Tucson & Mesa, Arizona
    272
    or take a socket that is just a shade smaller than the bearing housing put a bolt through the hole with a bigger socket on the other end for bearing to fall through and a nut on the bolt and pull the sucker out. once you get one out grind down the old bearing just enough so that it wound get suck back in the swingarm and you know have a bearing push-er-outer tool for the other side. oh get some fender washers too.
    1986 250R
    Ported Polished
    Paul Turner Head domed and milled
    Boyesen Rad Valve
    38mm carb
    Uni Air Box eliminator
    Full FMF Exhaust
    85 350X (getting there)
    86 250R (Roller/Parts Bike)
    85 Tri-Z (Parts Bike)
    85 NQ50 Spree (sick ass campus bike)
    Bikes Had
    85 200X (restored)(SOLD!)
    84 Z50R (SOLD!)
    Las Vegas, NV.
    2,499
    Quote Originally Posted by VenomRS4 View Post
    I hope you rookies don't install the new bearings with the same removal methods!
    Masshole
    2,191
    May i ask whats so wrong about using heat? And please dont reply with "it makes it brittle"
    Nov 2002
    Kirkville, NY
    3,831
    I had a friend tack weld a nut to the bearing race then I threaded a rod into the nut through the swinger and tapped the bearing races out, worked great and didn't hurt the swinger at all. I had him practice on the stocker before doing it on the westcoast....
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
