Results 1 to 8 of 8
Thread: draining fuel on a '83 ATC 250R
    ATCT is offline Just Too Addicted Arm chair racerJust too addicted
    Dec 2005
    Phoenix, AZ
    709
    OK, this question isn't a joke, although it might seem to be. I am shipping the trike via ForwardAir, which requires one to drain the fuel. I let the owner know this and he's stating he might have to remove the tank to drain it. This can't be correct, is it? I've owned 3 ATC's in my time (125M, 200X, 350X) and I don't recall any of them being difficult to drain the tank.
    You can just remove the fuel line from the tank or the carb, correct? This can't be that hard on an R, is it?
    I need to know what to tell him. Although not a big deal, I'd rather not have to put the tank back on when I get it. I just want to check fluids and hit the trails.
    Thanks for the help.
    1984 Honda ATC250R
    Pa.'s Highest City
    8,058
    You city folk are funny...
    Its one bolt that holds the back of the tank on.. the front is held on by two grommets.
    either pull the fuel line off the petcock and drain... or take the tank off,,, remove cap and turn upside down. simple really.........
    Dec 2005
    Phoenix, AZ
    709
    I try to be as humorous as possible.
    1984 Honda ATC250R
    Dec 2002
    deer park, texas
    2,336
    If you just pull the fuel line it will not drain completly for shipping. He will need to go ahead and remove the tank, pour out all the fuel and let it dry out in the sun.
    STL
    3,560
    I just delt with this when I sent my tank to syko lincoln to have him paint it. its not as simple as it sounds, removing and turning upside down to empty it doesnt work completely: theres a lip around the hole that keeps some in. I ended up shaking it upside down and then stuck some shop towels in it to soak up the last few ounces worth that I couldnt remove. you could also remove the petcock completely, the stem on the petcock actually makes it hard to get every little bit out of the tank so taking it all the way out helps too.
    I ended up spraying it out with brake cleaner and then forcing high pressure air through to dry it. Wrapped the tank in 2 trash bags and boxed it up, then sprayed some axe body spray to mask the smell. The usps, ups, and fed ex are anal about things smelling like gas when you ship them
    but shipping an entire trike is different, good luck getting the gas out!
    Dec 2005
    Phoenix, AZ
    709
    Quote Originally Posted by barry_mann View Post
    Thanks for the help. I'll let him know.
    1984 Honda ATC250R
    Dec 2005
    Phoenix, AZ
    709
    Quote Originally Posted by ATCaddict View Post
    Thanks a lot. Hopefully they don't expect it be perfectly drained. We'll see, I guess.
    1984 Honda ATC250R
    STL
    3,560
    ya its a pain to try to get it completely empty espescially if your on a short time frame due to shipping.
