Results 1 to 13 of 13
Thread: winter riding gloves?
    Apr 2006
    PA
    1,464
    What does everyone use for extremely cold winter rides? Last winter I always weared 1000g gloves but half way through every ride my hands would get horribly cold and had to stop to warm them up. What are some good gloves that I wont freeze to death in on the long rides???
    Phoenix, AZ.
    6,719
    I used to wear two at once. A thin cotton glove with a thick winter glove on top of that. A big thing that helps a ton is to block the wind with some hand guards. There's a lot of different kinds on the market. Even some that are fabric that you put your hands into kind of like a huge oven mit. If need be you can even make something. Anything that will shield your hands from the wind will help.
    Columbia
    5,131
    Gets some snowboarding/ski gloves!!! Waterproof, and wind resistant.
    Sep 2005
    Lipetsk, Russia
    2,824
    I've had lots of this kind of trouble in the winter time myself. Riding in -30 F weather at 50+ mph on a sled with no way of blocking the cold wind from your hands gets old really quick.
    Handguards work AWESOME if you get some decently large ones. I remember actually being able to wear regular Fox or Shift riding gloves a couple warmer days last winter, because I had some nice Acerbis handguards on my Yammi sled. I also have handmade "ghetto-rigged" handguards more than once, from gallon milk jugs and even just tarp in front of my gloves. Every little bit helps, believe me.
    Winter gloves are always good to have, and if you have a twist throttle on your trike, you'll be able to operate it just fine. I rode in my winter gloves on my YZ80 when it started to get cold here, and I never got cold and never lost control of the throttle.
    I would personally recommend handguards (Sportech makes really nice big ones that block a lot of the wind) and a hotgrips system, then you might be able to wear thin gloves. Otherwise, just get some nice thick winter gloves and you'll be fine.
    I'm back in the USSR...
    Jul 2006
    western ny
    3,366
    i use snowboarding gloves for winter riding.
    GIT IT RAAAGGGGG !!!!
    Apr 2006
    PA
    1,464
    Well I think that the wind was a huge problem too. I ordered some new thor ride cold weather gloves and im going to get a pair of hand guards from a friend that ill make work somehow. I think the hand guards would work really well too, I never really put that into perspective.
    Sep 2005
    Lipetsk, Russia
    2,824
    What kind of handguards are they? Like I said, Sportech makes some really nice ones, they're only 50 bucks and you can get them in all sorts of colors, and in a colored chrome finish too. It'll look trick! Powermadd guards are smaller and protect less. Acerbis ones come in about 4 different sizes, and the bigger ones are good but the smaller ones don't do much.
    Apr 2006
    PA
    1,464
    there kawi green acerbis off a kx250. There big, they cover your whole hand. should work good
    Sep 2005
    Lipetsk, Russia
    2,824
    Yeah I had some Acerbis ones on my Yami 500SX sled last winter and they worked AWESOME. You barely got cold.
    Yep, I wear KOMBI's and I'm nice and warm....
    Jun 2003
    Anchorage/Homer, Alaska
    480
    Snowboarding gloves always felt baggy to me; I prefer just a good winter glove. I have a pair from Sportsman Warehouse that have a Gore-Tex outer and rubber palm. The cuff goes about three inches past my wrist and is tightened with a drawstring to really seal the cold out. I think that feature gets overlooked alot. I wear these gloves when I'm downhill skiing.
    I'm thinking about putting heated grips on my SX.
    1985 ATC 250ES, Big Red
    1984 ATC 125M's, 1.5 of 'em
    1983 ATC 110, BLUE!
    1974 ATC 70 Pink?
    Aug 2006
    new hampshire
    914
    check out the powermadd gauntlett. i have that on my bike and havent had any issues with cold hands they are a stay open design.
    go here and get the color you want.
    http://www.roxspeedfx.com/cgi-bin/ca...?subcat_id=257
    the aluminum mounts are much nicer then then the kit powermadd offers.
    heres is what the look like installed
    http://www.atvriders.com/atvnews/pow...dgauntlet.html
    these are the best hand gaurds in my opinion. you can remove the black insert and then they are vented. theres other options availible also.
    1982 ATC 70
    1983 ATC 200E yard rat
    1984 ATC 200X
    1984 ATC 200S (X2)
    1985 ATC 70 (X2)
    1985 ATC 200S
    1985 ATC 250R
    1986 TRX 70
    1986 ATC 350X
    2004 kfx 700 XC
    2006 prarie 700 XC
    2009 Brute Force 750
    2020 CF Moto 600
    Apr 2006
    PA
    1,464
    I put on the acerbis guards today off of my friends old dirtbike and they are pretty nice but the lime green just dosent look right! Thoes powermadds look nice, im going to buy a pair of thoes as soon as I get my new bars. Should work really nicely. Thanks for the info!
