Well I got the Swingarm on the Tri-Z earlier today no problem. Looks awesome anyway. Will have to get pics as soon as I can. :-D
My chain idea did not work. the 84 tecate's stock rear end is so short that the extra long chain I have for it that I have to use with its +2 swingarm is the same length as the stock length chain I took off the Tri-Z! I was afraid that was gonna be the case, but that's OK, I need new sprockets and a new chain for the Z anyhow. I've got a 14 on the front now and I would like to leave the 14 and also drop the rear down a couple teeth and try that with the 18" tires.
As far as brake lines go, I have a longer braided steel line for my 84 Tecate. Believe it or not, the stock Tri-Z brake line was plenty long enough for this +2 Swingarm. Still has lots of slack, so travel won't stretch it tight either.
1986 Tecate
1984 Tecate
1985 Tri-Z
1986 ATC350X
1985 ATC250R (2)
1985 ATC125M (2)
1982 ATC70 - Original Owner
175 TriMoto Frame with Pro-Tec Rear Suspension
3-Wheelin' since '82
