ok, i bought the bike. when it was running, it sounded like there were migets in there withs trying to get out.
Solution: buy main bearings, rod kit, crank.
so, the main bearings, seals, rod and bearings, and crankshaft are new (crank newly used, all in tolerances)
so upon re-assembly (using old top-end, no fresh bore piston, rings, etc) the knock is still present, although not quite as loud as before. the knock did not go away and comeback, it was present upon the FIRST firing.
the piston wrist-pin was not loose on the wrist pin bearing,, whole assemble is nice and tight, Eliminating (i think) bottom end bearing trouble.
could it have been the piston in the top end making all that noise?
possible reasons include:
1. Timing off
2. Piston loose and rattling inside cylinder
3. well, its your jobs to give me this possibility.
so, how do you set the timing on this thing? the only way to adjust it from what i can tell is to remove the flywheel, but then you cant adjust while its running to get it right.
